How To Check If You Have Limited Slip.
Ok boys and girls.
Here's how you can check if your differential is limited slip or regular.
1. jack up both front wheels. You can jack up under the cross member if you have a floor jack, or use two separate jacks under jacking points on both sides.
2. While looking at the opposide side wheel, spin one wheel by hand:
If both wheels spin the SAME direction- You have Limited Slip Differential
If both wheels spin in OPPOSITE directions- You do not have Limited slip.
I did this with the car in park and again in gear and it was the same result.
Source: Believe it or not, Pep Boys; and it was confirmed by the local Nissan Dealer Service Dept as the way to know.
Originally Posted by sagamax
check your vin number i beleive that there is a V at the end of the tranny code. correct me if im wrong somebody???
rbaker100
Sep 25, 2015 07:52 PM
, but just to make sure I understand right what the LSD is, Can you guys explain to me what it is? Thanks
