G35 HIDS on 6th Gen SE
Old Apr 3, 2005 | 11:01 PM
05MaXiMaMenG's Avatar
Anybody know if the 03 G35 Bulbs, ballasts and harnesses will work with the 6th gen Max? i got a set of G35 HIDs but arent sure if they would fit. I was considering it cuz infiniti is nissan thought that they might be similar.
Old Apr 3, 2005 | 11:29 PM
Killer99max's Avatar
Custom Molding King!
what the problem with yours, did you have the base model maxima? I dont see why it wouldnt fit, I think those projectors wont work though, they might be halogen projecotrs, then again it might be like audi is and uses the same halogen projectors they use for hids, what bulb size is your projector headlight? Or do you have hids already and they are just broken or somthing?
Old Apr 4, 2005 | 12:06 AM
nyautostyle's Avatar
whats wrong with the maxima HIDs? im pretty sure its the same bulb they use, unless its D2R.. i'll find out for you tomorrow if i get the chance.
Old Apr 4, 2005 | 10:12 AM
NismoMax80's Avatar
SuPeRmOd
look at the sticky
Old Apr 4, 2005 | 10:15 AM
msoemax's Avatar
nismo-have someone photoshop your avatar so it says read the stickies...
Old Apr 4, 2005 | 02:13 PM
04BlackMaxx's Avatar
The G35 has a reflecter housing, the 6th gen has projectors, the G probobly has D2R bulbs and the 6th gen has D2S...You would not get a good result in my opinion, nor would it fit. The housings are different and so are the bulbs so im sure you cant just use the G's bulbs and ballasts in a 6th gen.
Old Apr 4, 2005 | 02:23 PM
I have the 6th gen max non Xenon. And i have a pair of G35 headlight assemblies with the bulbs and ballasts and harnesses. The bulbs from the G35 are D2R, and i believe the headlights on my max are 9012 which are equivalent to 9006 so im told.
I was just trying to see if it would be a plug and play format since Infiniti is made by nissan. Its worth a try and saves me 400 bucks
Old Apr 5, 2005 | 09:26 AM
NismoMax80's Avatar
SuPeRmOd
Anyone know about how much it would cost to convert my 04 se to HID headlights?
see this?
and here
Old Apr 5, 2005 | 10:52 AM
NismoMax80's Avatar
SuPeRmOd
Originally Posted by MEXIDEV
Show me the sticky
I can not search the forums.
sure you can search. point and click... Stickies are at the top of the forum, they are stuck there so you can always find them. they are your friends. use them often. look in the Sticky How to...
Max139617
Sep 20, 2015 07:09 PM
hot04
Sep 18, 2015 06:14 AM
240tomax
Sep 13, 2015 03:28 PM
