KS replaced ($550 later) and loving every moment of it.
yes, for those of you that remember; I attemped to do the KS swap myself and messed up the whole job by not retorqueing (i think that's how you spell it) the lower intake manifold right. I was soooo frustrated with the whole job, so I had my local mechanic do it. In my opinion, he overcharged me. But who cares, after 2 weeks, i have my car back and it runs REALLY REALLY good.
KS sensors that give more power
I hope its not the one on 9th st.
naah......it's the one on foothill; A1 auto Care. They do excellent work , but charge too much. Oh well, at least now i know.
I once had a tranny rebuilt, but they got oil on the new clutch..so it chatterred right away.. so I took it back once and they are like 'it's fine.. drive it a few months and it should get better'... so a few months later it is even more ****ed and they say 'sorry.. warranty is over..'
Originally Posted by 92SE_Dave
Cool... it might even give you as much power as a $ 0.48 cent 500k ohm resistor bypass!!
I would've gone that route, but half of the org. told me not to. And if i'm not mistaken, someone just posted a couple of days ago that they just had total engine failure due to a bad tank of gas and they had done the KS bypass.
You did the right thing. I think that was actually 92SE_Dave that posted that but he posted it on april 1 so I assumed it was an april fools joke.
april fools joke
Yes that was me and it was an April fools joke. My car has been running better than ever with the resistor bypass. Everyone was telling me that my engine would blow up, so as an April fool's joke I said it did, then they had to lock up the thread because they all fell for it.
Yes ... they all fell for it.
Um no one fell for it.
I glad someone repaired their car correctly and is running the engine as per oem specifications. Your car won't blow up in week or a month. But
I'm glad you are having fun with Wiking. Expecially since he get 95 octane.
I probably should get my KS replaced soon, right now I'm also rockin the resistor. Without it though, I'm afraid of burning something up. My EGT's were climbing up to 1600° almost, and that was only half throttle.
you're doing a turbo with the knock bypassed
Brad. You are playing with matches after being doused with gasoline man. At the very LEAST buy one and bolt it to the exterior side of the block or something. Anything. I don't want to see another VE turbo parted out.
Originally Posted by Brad92SE
Yeah, it kept pulling back my timing like crazy. I'm running stock timing, and it runs much much better with it disconnected. I haven't heard any knock yet.
Originally Posted by «§»Craig B«§»
wrong
all 3rd gens have knock sensors
the VG is located in a different spot though and much easier to get to
Brad, the harness is only so long. So you don't have much of a choice. Somewhere on the radiator side of the block is really the only convenient choice. I'm in no way saying this is a good sub for having it in the proper place. I'm only saying, it's better than what you have.
Is there a good place to bolt one to on the block? I really want to try and do it soon, but I think that running with the knock sensor is almost worse than without it. The EGT's are sky-high, and boost is almost instant, since I'm guessing its pratically fire spooling up the turbo. I can even smell my exhaust wrap burning from the heat. Basically, with it connected, I get 6psi of boost at part throttle, 1500° EGT's, and massive amounts of fuel being dumped for probably less than stock power.
At least it's just screw out, screw in and go.
TRUST me. It's 10x easier:
You don't get to it until:
Originally Posted by avmaldo
Not that easy, the damn motor mount bracket(AT) blocks the side for a deep socket and a regualr socket. I had to cut my deep socket to replace it. Plus it is a little crammed.
