Just Did Tune Up And....................
Old Apr 5, 2005 | 09:52 AM
ganjahbaby7's Avatar
car is still missing does anyone have any knowledge of what it could be?I feel its the injectors.I changed plugs,wirescap&rotor,pcv,and air filter.
Old Apr 5, 2005 | 09:53 AM
Jeff92se's Avatar
I'm needing a caw
Which cylinder is missing?
Old Apr 5, 2005 | 09:58 AM
of the three in front its the one in the middle,not sure of the number
Old Apr 5, 2005 | 10:02 AM
DanNY's Avatar
Ad·min·is·tra·tor
sounds like #4
Old Apr 5, 2005 | 10:04 AM
Jeff92se's Avatar
I'm needing a caw
Clean the injector connector and measure it's resistance across the connector. If you can get at it.
Old Apr 5, 2005 | 10:11 AM
thanx guys i'll get that info to my mechanic
Old Apr 5, 2005 | 10:43 AM
MAXI's Avatar
Jeff... i wanna get your opinion on this.....a buddy of mine said that to get an accurate reading on the injectors, it is best to disconnect the negative terminal.
Old Apr 5, 2005 | 11:22 AM
DanNY's Avatar
Ad·min·is·tra·tor
ask your buddy why does it matter? you're just measuring the resistance between the 2 terminals on the injector itself. nothing else should be connected to the injector. the resistance is internal to the injector itself.
Old Apr 5, 2005 | 01:22 PM
MAXI's Avatar
he's probably thinking that the electrical current from the battery, since it is grounded, can interfere in getting an accurate reading????? i'l ask him tonight.
Old Apr 5, 2005 | 01:59 PM
avmaldo's Avatar
be sure to check your ks also.
Old Apr 5, 2005 | 02:21 PM
DanNY's Avatar
Ad·min·is·tra·tor
you're not taking resistance from a ground point...it's resistance from the injector and only the injector. it's like pulling the injector off the car and testing it...do u need a ground cable there?...nope.
Old Apr 5, 2005 | 02:29 PM
Vadim-93GXE
Are you sure the wires are installed in the proper sequence?
Old Apr 5, 2005 | 04:05 PM
aminus21's Avatar
I have the same problem (the missing at idle). i changed all the stuff he did, and i checked to resistence on 4 of the injectors. I coudlnt get to the other 2. All the injectors were changed about 6 years ago, with Nissan ones.
Any ideas???
Old Apr 5, 2005 | 04:06 PM
5 ltr. beater's Avatar
Just curious, what kind of plugs did u use?
Old Apr 5, 2005 | 05:21 PM
i used ngk plugs.but does a automatic 1990 sohc have a ks?
Old Apr 5, 2005 | 07:47 PM
aminus21's Avatar
No, VE's do though.
Old Apr 5, 2005 | 08:46 PM
Jeff583's Avatar
take off and clean all of the electrical conectors on the injectors with carb cleaner, i had this problem on my old max and there was some corrosion on the connectors, and by the way the 1990 vgs do have a knock sensor its just located in a different place
Old Apr 5, 2005 | 09:50 PM
avmaldo's Avatar
Originally Posted by aminus21
No, VE's do though.
Uh, yeah they do actually, don't post invalid information.
And they can cause an uneasy idle. Easy way to tell if the detonation sensor is bad is to run an ecu self diagnosis.
or do as Wiking say's and:
Originally Posted by wiking
Knock Sensor:
The knock sensor on VG30E engines is located under the rear exhaust manifold.
Just use an ohm meter at the subharness and check each terminal (going to the KS) to ground (battery negative). Resistance should be around 0.5 Meg Ohms (500,000 Ohms). When mine was bad it read 5 Meg Ohms (5,000,000)
http://internetautomart.com/maxima/3rdgen/tuneup.html?
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
Socalstillen
Sep 26, 2015 12:01 PM
zzznightmarezz
Sep 21, 2015 06:32 PM
Maxboy23
Sep 4, 2015 06:04 PM
