big 3 (dont kill me)
Old Apr 7, 2005 | 08:24 PM
generation3's Avatar
Can anyone tell me how much 4 gauge wire I'll need to do the big 3 in a VG? Also does Craig B have a writeup for it or anyone else have one for VG with pics?
Old Apr 7, 2005 | 08:47 PM
Scope's Avatar
Im izz sexay
Get about 10 feet (some for extra) You need neg to chassis. Neg to Alt. the third I am not sure on.
Old Apr 7, 2005 | 09:21 PM
NismoChi's Avatar
What is a "big 3"?
Old Apr 7, 2005 | 09:31 PM
Scope's Avatar
Im izz sexay
Originally Posted by NismoChi
What is a "big 3"?
Upgrading the grounds.
Old Apr 7, 2005 | 09:35 PM
MrGone's Avatar
Use 8 gauge, 4 is overkill and just plain ugly (except from battery to block).
Old Apr 8, 2005 | 12:49 AM
NismoChi's Avatar
I don't get it.
Old Apr 8, 2005 | 03:49 AM
Jbr8k's Avatar
What is a "big 3"?
Big 3= Battery neg- to chassis neg-
Battery pos+ to alt+
Alt neg- (mounting bolt) to chassis neg-
I personally used all 4 gauge and have no problems.It took about 5 feet pos+ cable and 6 feet neg-.
Old Apr 8, 2005 | 04:50 AM
Geerhed's Avatar
Moved on to BMW's :(
Do the grounds NEED upgrading in these cars?
I did run dedicated wires for my radio's 12VDC +/- directly from the battery (fused +) because the radio wasn't getting enough juice to power 200W (the off/on is still switched from the key, but the radio gets its power from the constant-hot line), but everything else seems OK.. never had a need to re-do the chassis grounds (I thought)...
As far as the grounds, why not do it right and get anodized braided copper? They're available in different widths, and if you buy the correct lengths with the ends already attached you don't have to worry about shoddy crimp joints. They'll easily outlast the car.
Old Apr 8, 2005 | 06:30 AM
Scope's Avatar
Im izz sexay
Do you have an amp and everything else other than HU power? Because there's this thing we have called the alternator whine and when you do the Big 3 it usually goes away. The big 3 also helps against dimming lights.
Old Apr 8, 2005 | 07:20 AM
hadman's Avatar
I only did the neg ground to chasis on the alternator.
When you did the positive alt to batt did you fully replace the original, or just double up with a new one?
Old Apr 8, 2005 | 08:39 AM
I plan to cover it with wire loom anyway. I already have 4 gauge from terminal to amp, I thought it was better to match wiring. I got two 500/1 and I'm adding a 300/4. I have dimming without the 300/4.
Old Apr 8, 2005 | 08:41 AM
-shock211-'s Avatar
remember when upgrading the gorunds to keep them as short as possible. the shorter the run of wire the more effective the ground will be.
Old Apr 8, 2005 | 10:37 AM
Alex_V
Or any eletronics as long as the wire length doesn't change the resistance of a sensor.
~Alex
Old Apr 8, 2005 | 10:44 AM
Michael's Avatar
Back in a 3rd Gen.
I thought you were going to ask about GM, Ford and Chrysler (commonly known as the big 3).
Old Apr 8, 2005 | 11:07 AM
Jbr8k's Avatar
QUOTE=hadman]I only did the neg ground to chasis on the alternator.
When you did the positive alt to batt did you fully replace the original, or just double up with a new one?[/QUOTE]
I left the originals and added extra cables..
Old Apr 8, 2005 | 01:12 PM
hadman's Avatar
Thought so. Just checking. Nice battery btw!
Old Apr 8, 2005 | 01:40 PM
maxitech's Avatar
blehmco sells ground kits specific to each motor in whatever color you want
Old Apr 8, 2005 | 03:01 PM
hadman's Avatar
Yeah, Matt's kit is great.
Old Apr 8, 2005 | 05:11 PM
AscendantMax's Avatar
Jbr8K, how much that optima cost ya? looks good, i need to get one soon
Old Apr 8, 2005 | 05:51 PM
Jbr8k's Avatar
There was a group deal going in the GD section and was lucky to get it for
$146 shipped about $40 less than what I had seen it for.
Old Apr 8, 2005 | 07:56 PM
Scope's Avatar
Im izz sexay
These are some nice prices.
http://forums.maxima.org/showthread.php?t=363680
Old Apr 8, 2005 | 11:22 PM
Geerhed's Avatar
Nope, no alternator whine, and no dimming lights. Even before I ran the dedicated lines from the battery: no whine, but really pitiful bass (called for too much power). Dedicated +/- 12VDC solved that little problem.
D Mason
Jun 21, 2016 04:43 AM
MichMaxFan
Sep 30, 2015 09:18 AM
