RS6 projector retro - Completed!
Originally Posted by meanbean
Thanks, the corner lights will be be given the AE treatment in the future. I'm too tired to do anything more this weekend.
Any more beam pattern pics? High beam?
Here are the additional cutoff pics. Also, the upper foreground shield has been removed from the projectors.
kevlo911: They are Xtec 6000k H3 HID fogs soon to be retroed into something different. (next project)
Wow that just looks amazing you do great work any pics of you actually doing it ? with the projectors out and head lights and stuff?? just wondering if not o well thanks for the pics btw
Here are some installation pics.
Relay harness w/ installed diaode for hi/low beam.
Lights and grill removed and ready for installation.
Ballast location for left side.
Ballast location right side.
RS6...aren't they running valeos?
did you happen to bend the shield at all? the cut off seems fuzzy..but there's a lot of color there.
also not to be a PITA...but the pass side one can use a slight adjustment counterclockwise so it's even with the driver side (cam angle?)...otherwise it looks ok.
RS6 was termed from the HID community to dub a Audi A6 bi-xenon projector made by Hella. The shield is indeed bent for color and the trade off is a slight drop in sharpness. The projector cutoffs are even in person so perhaps its just the angle of my pic. Thanks for your feedback.
yeah the cam was at a bit of an angle so hard to tell. looks good.
Originally Posted by DanNY
ahhh ok...the color is definitely there...just weird to see the fuzz on the cut off.
Originally Posted by BlueC
A lot of bi-xenon projectors dont have the sharpest cut-offs. The sharper ones you come across (S2000, Valeo) are only single-xenon. Rather have high beams than an extremly sharp cutoff. Cant really even tell that much in person, its still sharp.
also meanbean mentioned that he bent his shield a little to get the extra color. that makes the beam pattern a little blurry.
any reason for that? a bi-xenon should still have the shield there similar to the single beam projector. only difference is that it moves w/ a little motor for the high beam...but in low beam setting it should still have a decent line for a cut off.
Yes bending the shield will make it worse, but they arent very sharp to begin with. Mine are similar but not as blurry. I havent bent the shields much at all, mainly because they already have a decent amount of color to start with.
If you want razor sharp cutoff with incredible color then go for the LS430 or Evo8 projectors. Those projectors are the bomb (better than S2000) except the price is just too high. Thanks to everyone for their feedback and compliments.
Originally Posted by JSniper0
i agree with 1fstmax
the Black out doesnt seem to look as beasty as if it was just AE modded. Maybe completely blackout clearance light could help the look but I still dont like, but good job on the projectors and getting them to fit and work properly.
Originally Posted by MDeezy
I agree.
You tell me... All black doesnt look "beasty"? Looks fine to me.
I wonder how it would have looked in you painted it body color. I still think just AE modded is the sharpest look.
Here are some more beam pattern/cutoff pics that should convince everyone of the superiority of HID projectors.
Stock reflector housing w/ 100w halogen 9007 bulb - low beam
RS6 projector w/ 4100k HID D2S bulb - low beam
RS6 projector w/ 4100k HID D2S bulb - high beam
