19x9 or 19x8 on a 2k2 Max
Old Apr 19, 2005 | 10:22 AM
mad wayz's Avatar
Was sup everybody was the best size in width with the 19 wheels 8 or 9, also what size tire,,, i just dont have a clue. let me know thanks guys
Old Apr 19, 2005 | 06:50 PM
Ammi's Avatar
350 Detroit Muscle
8.5" unless you want staggered setup.
Old Apr 19, 2005 | 08:37 PM
mad wayz's Avatar
what if in the rim you want they only have a 8 width and a 9width?
Old Apr 19, 2005 | 11:08 PM
Ammi's Avatar
350 Detroit Muscle
I would get either 8 all around or 8 front and 9 back
Old Apr 19, 2005 | 11:23 PM
SEmy2K2go's Avatar
Go BUCKS!!!
19"x8" is a common size used by many on this fourm, including myself.
Old Apr 19, 2005 | 11:34 PM
steven88's Avatar
Need A Light?
I think 19x9 at all four corners would work @ 30mm offsets....255/35/19 is the tire you want....
just for reference...I am 8.5 wide @ 42mm offset with 245/40/18....i am slammed over 3.5 inches from stock...and my fronts rub slightly only when locked out to the left....I think if I got my rims in 35mm offset...they wouldn't rub at all...
Old Apr 19, 2005 | 11:56 PM
NmexMAX's Avatar
dot dot dot ...
I would go with 8.5" ... That's just IMO though.
Old Apr 20, 2005 | 08:29 AM
mad wayz's Avatar
So are those 19x8 i see right there , are you lowerd and what size tire are u running? looks good and thanks for the other pics on the other post....
Old Apr 20, 2005 | 01:57 PM
$tillenmax2k
Won't fit properly on the front with that offset and tire.
If you had a lower offset, you could possibly rub more. Because the outer edge of the wheel/tire is farther away from the steering axis, so it swings in a wider arc when you turn the wheel. Torque steer under acceleration and braking would also be more pronounced.
mad wayz: go with the 8" and avoid fitment issues.
Old Apr 20, 2005 | 02:17 PM
steven88's Avatar
Need A Light?
thats weird? I've seen a 5th gen with 9 wides in the front with 265's and a 35 offset...perfect fit and no problems from what I heard. So I assume that with maybe 30-35ish offset with a thinner 255 width...it would clear okay....
I had a 4th gen with 245's and 8.5 wide rims....it cleared perfectly fine....I don't see how a 5th gen with a bigger fender wheel well can't add 255's on 9 wide rims......
Old Apr 20, 2005 | 02:31 PM
SEmy2K2go's Avatar
Go BUCKS!!!
No sweat. Yeah, my wheels are 19"x8" with 245/35/19 Nitto 555 tires. I am lowed on Maxspeed springs with OEM struts (for the time being).
TallTom
57
Oct 14, 2025 05:16 PM
litch
123
Jan 4, 2024 07:01 PM
Apr 16, 2020 05:15 AM
magiconthetire
Oct 26, 2015 09:03 PM
