Chip
Old May 10, 2001 | 12:42 PM
dkbl97SE
This kid at my school who has a '96 GXE told me he put a chip in his Maxima that adds 30 horsepower. Does such a chip even exist, and if so, could he have put it in himself without reprogramming the computer?
Old May 10, 2001 | 02:29 PM
Daniel B. Martin's Avatar
There are chips which improve performance. Maybe 30 hp was claimed but I think that was exaggerated. Installing the chip is reprogramming the computer because the chip contains the programs.
Old May 10, 2001 | 10:48 PM
MaxedOut97SE
I would think that a chip would do more harm than good. Why would you want to mess with the computer's programming? Raising the redline? That's a big no-no in my opinion. I dunno though, I could be wrong.
Old May 11, 2001 | 04:36 AM
The programs in the chip are used by the Engine Control Module to control the fuel mixture and spark timing through a wide range of operating conditions. The term operating conditions refers to things such as engine coolant temperature, ambient air temperature, barometric pressure, throttle position, engine rpm, exhaust stream oxygen concentration, etc. Under most combinations of operating conditions the programs seek to provide good fuel economy and minimize exhaust emissions. The intention of the aftermarket chip designers is to provide more engine power by making small sacrifices in fuel economy and emissions control.
Old May 11, 2001 | 07:27 AM
Dreizehn's Avatar
Availablity
Where can you find them???
Old May 11, 2001 | 10:16 AM
doz's Avatar
doz
Check out this group deal for 95/96 ECU upgrades it has all the info you need:
http://forums.maxima.org/showthread.php?threadid=38766
Old May 11, 2001 | 05:04 PM
robert@gforce
Upgrading or optimising a Engine Control Computer program is done for all the same reasons you would do anything else to a car.
POWER
Not all "chips" or ECU upgrades are the same, so buyer beware, but if done properly it is in a lot of cases the biggest HP per dollar upgrade you can buy. The installation is simple so you can DIY, the upgrade hardware is invisible and it is a noticable improvement to the Maximas power, response and torque output. The reason for this is because Nissan, as do most other manufacturers besides Honda, Acura, detune the ECU program which lowers the output of an engine for various reasons. Most pre-production Magazine test cars, almost all, have tuned ECUs for a "true" power output.
You are correct about raising the redline it is not recommended for 99% of upgrade applications.
Old May 11, 2001 | 06:19 PM
robert@gforce
Originally posted by Daniel B. Martin
The programs in the chip are .........
A little mis-information needs to be clarified. I am in the "chip" buisness and have been in the automotive aftermarket industry, mainly in a technical position in manufacturing /distribution, for just over 10 years so I am qualified even though I don't own a Maxima.
The Engine Control Module or Engine Control Unit keeps the engine running optimally by using various sensor inputs to perform centralized control over EFI, ESA (spark advance) and ISC. Some ECM,ECU, VQ Maximas NOT included, keep the entire Engine Control Program on a PROM "chip" that can be desoldered and replaced.
To elaborate:
Under most operating conditions, idle, cruising, and light throttle, the ECM,ECU will try to maintain a predetermined mixture. Under heavy to full throttle applications the EFI program reads straight from maps, the very maps optimized in our upgrade, for fuel and spark timing. Fuel economy and emissions are not involved when you jump on it.
This is not true at all. As explained above under any decent throttle opening the EFI system reads off of a map to set spark and fuel so fuel consumption and emissions are not addressed by the ECM,ECU so they can not be effected. The truth is really the opposite of your statement. Many think that a car with an ECU upgrade will more power so it burns more fuel right? This is a really common Fallacy. The truth is that 9 out of 10 engine control programs run a super safe, super rich mixture to prevent detonation under WOT. Knock sensor signals are not used by the ECU under WOT (mostly because of noise) so some vehicles, mostly Turbo (probably the VQ30DET), will run up to a worse case of 10:1 A/F ratio. We usually tune Turbo cars to 11.5-12.5:1 (much leaner for NA apps)for a good balance of power and safety.
So most ECU tuned cars while making more power will run cleaner and use less fuel. Strange but true!
Apr 16, 2020 05:15 AM
doctorpullit
Apr 23, 2017 05:35 AM
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
Dasmith
Sep 23, 2015 08:28 PM
Jamie Bowen
Sep 6, 2015 09:59 PM
