Chip
Originally posted by dkbl97SE
This kid at my school who has a '96 GXE told me he put a chip in his Maxima that adds 30 horsepower. Does such a chip even exist, and if so, could he have put it in himself without reprogramming the computer?
Originally posted by MaxedOut97SE
I would think that a chip would do more harm than good. Why would you want to mess with the computer's programming? Raising the redline? That's a big no-no in my opinion. I dunno though, I could be wrong.
Check out this group deal for 95/96 ECU upgrades it has all the info you need:
http://forums.maxima.org/showthread.php?threadid=38766
POWER
Not all "chips" or ECU upgrades are the same, so buyer beware, but if done properly it is in a lot of cases the biggest HP per dollar upgrade you can buy. The installation is simple so you can DIY, the upgrade hardware is invisible and it is a noticable improvement to the Maximas power, response and torque output. The reason for this is because Nissan, as do most other manufacturers besides Honda, Acura, detune the ECU program which lowers the output of an engine for various reasons. Most pre-production Magazine test cars, almost all, have tuned ECUs for a "true" power output.
You are correct about raising the redline it is not recommended for 99% of upgrade applications.
Originally posted by Daniel B. Martin
The programs in the chip are .........
The programs in the chip are used by the Engine Control Module to control the fuel mixture and spark timing through a wide range of operating conditions. The term operating conditions refers to things such as engine coolant temperature, ambient air temperature, barometric pressure, throttle position, engine rpm, exhaust stream oxygen concentration, etc.
The Engine Control Module or Engine Control Unit keeps the engine running optimally by using various sensor inputs to perform centralized control over EFI, ESA (spark advance) and ISC. Some ECM,ECU, VQ Maximas NOT included, keep the entire Engine Control Program on a PROM "chip" that can be desoldered and replaced.
Under most combinations of operating conditions the programs seek to provide good fuel economy and minimize exhaust emissions.
Under most operating conditions, idle, cruising, and light throttle, the ECM,ECU will try to maintain a predetermined mixture. Under heavy to full throttle applications the EFI program reads straight from maps, the very maps optimized in our upgrade, for fuel and spark timing. Fuel economy and emissions are not involved when you jump on it.
The intention of the aftermarket chip designers is to provide more engine power by making small sacrifices in fuel economy and emissions control.
So most ECU tuned cars while making more power will run cleaner and use less fuel. Strange but true!
Apr 16, 2020 05:15 AM
doctorpullit
Apr 23, 2017 05:35 AM
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
Dasmith
Sep 23, 2015 08:28 PM
