pulled someel codes wondering is you guys could help
pulled some cel codes wondering is you guys could help
i have a 95 max auto 160,000 miles and i pulled some codes and was wondering if you guys could help me out - i was wondering what u guys think it is, how hard it is to do myself, cost of parts to fix, and cost of a dealership to fix it- thanks a lot here are the codes i pulled
0304 - Knock Sensor
1008 - EVAP Canister Purge Volume Control Valve
0302 - EGR System Hi/Low Flow
0304 - Knock Sensor
As crazy said, clear the codes and see what if any come back. If the same codes come back, then check/clean the EVAP purge control valve and clean out the EGR system.
The KS code is probably coming up because of the EGR system problems.
Please help new user with ECU code
I'mk posting here because according to the forum's policy I can't create a new thread. The check engine light in my 96 Maxima is on and I just tried to read an ECU code. I'm getting 9 longs then 1 then 3 longs and then 4 shorts. I've tried many times and always get this sequence. Does it mean 1304 which I can't find an explanation for? Thanks in advance.
AS stated 0304 and 0901. Change the KS (knock sensor) and see if that gets rid of both codes. If the 0901 come back you'll need a new o2 sensor.
in the 4th gen section there are stickes that can help you with more information.
Change the O2 sensor and the KS code should go away.
The KS code is usually always considered a ghost code when it's associated with an O2 sensor.
Originally Posted by njmaxseltd
Actually it's just the reverse.
Well there you go. I stand corrected.
Incredible forum: thank you, guys, so much for prompt advice. I've been pretty lucky with the car so far: 10 years, 155Kmi and it's only the third time I need to fix something. First two were some AT hose and cv boots. Also I have to admit that my wife's been putting regular gas last 2 years. My other car is g35 and it doesn't look like it will be as reliable as maxima: many little things went wrong in 2 years I had it. Thanks again.
Confusing, but I would venture to say that both cases would be probable and related if you get both codes at once. But, if both fron O2 sensors maintain a constant value, the ECU will read from the rear O2 sensor to maintain the correct Air/Fuel mixture.
0304 - Knock Sensor
i have those codes to i went to pepboys to see how much a EVAP Canister Purge Volume Control Valve cost and the guy looked at me like i was speaking hendo or something. then told me that they dont carry those. does anybody know where i can get one?
CorollaULEV
30
Aug 9, 2021 08:11 PM
doobadoo
Aug 15, 2015 06:43 PM
Nintensity
Aug 13, 2015 05:41 PM
