Max reachin 100,000
Max reachin 100,000
Hey guys.. My car is about to reach 100,000 miles.. I was wonderin what kind of services I should get done, what should get checked and replaced.. Also, I dont think I ever got a tune up, should I get that done also? Thanx a lot..
The obvious question is: how long have you owned the car and what was the mileage when you bought? What do you mean by "I dont think I ever got a tune up ...". WTF, either you did or you didn't. How you wouldn't know makes no sense whatsoever.
Why don't you do us a favour - list what you have done, the mileage at the time, and when it was done. Absent that information, I would recommend doing everything to your car. Does that help?
I'm assuming you just aquired the car since you have no previoius knowledge of tune up's. Now a days normal shops consider just a simple spark plug change a tune up, but I think there's a lot more to it.
-oil change
-spark plugs
-transmission oil change
-radiator fluid change
-air filter change
-throttle body cleaning
-fuel filter change
-check ecu (knock sensor code is hidden)
These two links will be a start...
http://web.archive.org/web/200111091...k_service.html
http://vbxmaxima.8m.com/maintenance.html
Most importantly, go through the sticky links they will get you through 70% of your problems with your max and/or questions about it
-oil change
-spark plugs
-air filter change
-fuel filter change
litch
123
Jan 4, 2024 07:01 PM
jmlee44
Oct 2, 2022 02:13 PM
Andy29
Sep 29, 2015 05:32 AM
