Ball joint
Old May 3, 2005 | 06:06 PM
elusive_max's Avatar
Ball joint
has anyone try to replace this and if so how hard is it
Old May 3, 2005 | 06:09 PM
Stuntin' 101's Avatar
your better off buying the complete control arm from ebay.. you can get an aftermarket one, with all the bushings, and the ball joint, already pressed in for like $70
Wheelie King's Avatar
Front ball joints have to be pressed. I didn't have a press so I got raped at my locsal shop. I paid $250 for my front passenger side ball joints and didn't even get a dinner out of it. Maybe someone else has better experience. You might save money by taking off the wheel assembly and taking it to a shop for pressing. That's what I wish I had done.
pjp900's Avatar
like stuntin'101 said, its just eaiser
Old May 3, 2005 | 06:11 PM
my lower driver side ball joint is loose so im wondering how to fix it
Old May 3, 2005 | 07:16 PM
MaximaSE96's Avatar
Maxima Owner
unless u want to rent a press from like autozone but its just easier to get the new control arm.....u get new bushings like fore mentioned above...then u can do it urself cause its jsut swapping control arms...the only way to fix a loose ball joint is to replace it
Old May 3, 2005 | 07:28 PM
Sirk's Avatar
How can you tell if it's loose? My car makes a single popping noise during low speed turns. Is that the ball joint?
Old May 3, 2005 | 10:03 PM
97MaximaSE's Avatar
could be your cv joints.....i just had my sway bar links replaced and the car feels and sounds so much better
Old May 4, 2005 | 07:09 AM
200KStrong's Avatar
My brother and I put about 8 hours in trying to use a press on the ball joint. We tried every angle but unless you have a torch to heat that baby up so that it expands, you are SOL. I finally went to MasterCare and they hooked me up in about 45min. and for only $130 for the passenger-side joint. My advice, don't waste your time.
Old May 4, 2005 | 08:14 AM
96mAx2fast's Avatar
what does that look like?? what type of problems are caused by a bad ball joint??
Im assuming that, that is not the same as the CV joint.. Thanks for the help
Old May 4, 2005 | 08:41 AM
knight71's Avatar
Check this thread:
http://forums.maxima.org/showthread.php?t=391391
litch
123
Jan 4, 2024 07:01 PM
James92SE
142
Jan 2, 2024 09:23 AM
user 11122324
42
Jul 18, 2022 03:35 PM
D Mason
Jun 21, 2016 04:43 AM
ivorton23
Sep 26, 2015 09:47 AM
