01 SE wheels with 300z Brake Upgrade ?
Old May 4, 2005 | 07:57 AM
1phtmax's Avatar
i was not planing to get new wheels but i need new brakes i know the wheels will not fit. If i get spacers and longer Studs will that work and if so how bit of a spacer do i get and how long do the studs need to be ?
Old May 4, 2005 | 09:41 AM
Maximathug's Avatar
Go to tire rack they have the spacers and stud, your looking at about $120-130, this is for the 10 mm spacer pkg.
Old May 4, 2005 | 01:50 PM
Colonel's Avatar
Old Fuddy Duddy
If you have the stock 17" OEM Rim from Nissan, you are NOT going to get the kit to fit under it. Period. Regardless of spacers. The ID of the rim is not going to allow it. You will not even be able to get the rim over the TT 300 calipers. Its a distance from center of the hub issue. Not a distance from the face of the rotor issue.
I have the TT kit.
Old May 4, 2005 | 03:33 PM
1phtmax's Avatar
I have the TT kit.
I was to that it would fit. but what you are saying is that the calipers will not fit with stock oem wheels
BkGreen97
Apr 2, 2016 05:47 AM
Maxboy23
Sep 9, 2015 10:37 AM
dcam0326
Sep 8, 2015 11:02 PM
Maxboy23
Sep 4, 2015 06:04 PM
