need help troubleshooting
this has been going on now for some time and it has gotten more frequent. the squeaking seems to be coming from the front wheels on both sides. it only goes away after i hit the brakes but then comes back later as im driving. its becoming really annoying. i posted something like this before but got no reply. also im getting a vibration in the pedal when i accelerate. fyi im dropped on gc/illuminas and i need an alignment. does anyone know what both of these problems could be?
hmm okay ill change my pads soon and yes i get a mad vibration when i brake from 40+ mph.
so changing out the pads will eliminate the squeaking noises when im driving? seems too easy to be just that...
slide pins cannot warp rotors.
1) get the alignment
2) get the rotors cut
3) clean and regrease slide pins
4) also while your in there, clean and regrease any parts that make any metal to metal contact. (except for pad to rotor)
5) install new rotors.
okay thanks guys. my mechanic installed semi-metallic pads so i get a grinding sound everytime i brake. noisy and annoying but i have a lot of pad left. didnt know that could cause a problem.
a couple more questions: where are the slide pins located? and can i use lithium grease to regrease? what do you mean by cut rotors? (resufacing?) i think itd be easier to just get new rotors and pads together, right?
CAN-Toronto FS: Emanage Ultimate and plug/play Harness
knight_yyz
Nov 6, 2015 02:34 PM
CAN-Toronto FS: E-Manage Ultimate and patch cable
knight_yyz
Oct 24, 2015 08:05 AM
