Problem with smoking brake. Please help!
Old May 10, 2005 | 04:27 PM
enjoi's Avatar
I installed new pads and rotors in the back of my car yesterday. I noticed the second brake was much harder to turn that piston thing (sorry not mechanic). And today when I was driving I smelled a very foul odor and saw my tire was smoking. I pulled over and took a look, and my brake pad is touching the rotor and making a bad smell and heating the rotors up. My pads and rotors that were replaced were in pretty bad shape. I'm wondering if I need to bleed my brakes, replace my caliper, or what. I'm not sure, but the other side is fine. Any ideas? Thanks!
Old May 10, 2005 | 04:45 PM
joeeey's Avatar
You are going to have to replace that caliper, then bleed the brakes
Old May 10, 2005 | 04:58 PM
JPMax's Avatar
What's next!?..
Sounds like that caliper has seized and will need to be replaced and fluid bled.
I had this problem last year. One was completely stuck and one would barely move. So I just replaced the both of them. You can get some rebuilt ones at autozone for about $80 each after core refund.
Also check the emergency brake cable. Make sure it's not stuck.
Old May 10, 2005 | 05:00 PM
enjoi's Avatar
I just called Advanced Auto Parts, they they have calipers for $78 each with a $55 core refund. So tomorrow I'll stop in and replace it and see if it does the trick. Thanks for the help.
05RLS2
Sep 27, 2015 09:24 PM
homewrecker
Sep 24, 2015 07:01 PM
ajahearn
Sep 19, 2015 03:03 PM
ballerchris510
Sep 10, 2015 09:35 PM
