Rear Main Seal with clutch replacement?
That,s odd.........
Originally posted by Daniel B. Martin
Replace it if it is leaking, otherwise leave it alone.
Re: That,s odd.........
Originally posted by dch95
I would have bet that you would have said to replace it just for preventitive maintenance
Either way.
I did it when I had my clutch replaced on my other car. The guy at the shop was really cool and told me if I wanted to go pick up the part, he'd put it in with no additional labor charge (it's like a 5 minute job with the trannmission off).
However, you can look at it the other way. If it ain't broken, don't fix it. If it doesn't leak now, messing with it might cause it to leak later
-V
-V
1) If it was a part which is a known trouble spot in the engine, I would say "replace". The rear main seal is not a known trouble spot on the VQ30DE.
2) It is easy and fast to replace the rear main seal if you already have the flywheel off. If you are doing a garden-variety clutch replacement you might not want to remove the flywheel. Some techs say "always resurface the flywheel when doing a clutch job." These are the same guys who say "always resurface the rotors when doing a brake job." I won't say they are wrong, but I prefer to use judgement. Look at the flywheel (or rotor) and decide what it needs.
vingodine
45
May 21, 2016 12:46 PM
Huttig2009
Sep 25, 2015 03:31 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
carlosvq30
Aug 17, 2015 11:32 AM
