rough idle?
Old May 17, 2005 | 09:43 PM
vortechpower's Avatar
rough idle?
Idle around 500 and below. Car stalls out sometimes. Pulls like a champ though. ses light on.vaccum at about 10 hg. Blitz bov not wanting to bleed at idle unless I take out the air temp sensor from charge pipe before throttle body. V1 kit. I think I can hear a vaccum leak but... Anyone have any ideas?? thanks
Old May 19, 2005 | 05:07 AM
Stephen Max's Avatar
Low vacuum and rough, low idle point to a vacuum leak. So does your bov not wanting to open at idle.
But why your bov opens when you remove the IAT sensor is beyond me...
Old May 19, 2005 | 10:03 PM
PTownMax's Avatar
I still miss the max
not a clue but good luck man
when you comin back down?
Old May 19, 2005 | 11:14 PM
matty's Avatar
Shouldnt you see about 18-20 HG of vacuum ?? thats what I normally see
-matt
Old May 20, 2005 | 08:00 AM
MAXimumHP's Avatar
Mines idles rough below 500 too. It's always idled really low like that, I think it just doesn't like running that low with the S/C. If I bump up the idle, it goes away. I'm pretty sure I run more vacuum than 10 hg as well.
On a similar note, Mine car will stall on engine decel at times. Usually when I take a corner, and the rpms are dropping, once I turn the wheel the extra engine load kills the engine. I've tried everything and can't get it to stop. Kinda dangerous losing power steering mid turn.
Old May 20, 2005 | 02:24 PM
Used to run just fine. Think im gonna hook it up to a smoke machine to find the leak. Yeah the bov doesn't want to release any air at idle?? Maybe the bov is busted but I think a vaccum leak is the cause. THis all started at the track about a month ago... Ran a 13.6 though!!
Sup Jeff, I should be back soon!
Old May 20, 2005 | 02:58 PM
iansw's Avatar
Or you have a HKS SSQ BOV - which will never release air at idle.
Definite vacuum leak tho.
Old May 21, 2005 | 04:21 PM
Just dropped the transmission lastnight! Had to start off in 4th. This is from a long term issue starting with a bad install on the clutch over 2 years ago....
Looking back the vaccum leak wasn't all that bad.
Old May 21, 2005 | 04:49 PM
fmaru's Avatar
no doubt vacuum leak!
Old May 24, 2005 | 06:38 PM
PTownMax's Avatar
did you get a new tranny yet?
Old May 26, 2005 | 08:27 PM
No. I have been looking around. Best price is $750 with 40k. Need to do something soon! I get 1, 2 4 and 5th gear but sometimes 1 and 2 get jammed up. Im not sure how bad the damage is but my 5th syncro has been broke for 2 years so thats still an issue so I need to take it to someone and GET R DONE!
litch
123
Jan 4, 2024 07:01 PM
Unclejunebug
Apr 2, 2016 05:42 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
