Temp effect on Dyno?
Old May 19, 2005 | 06:11 AM
dadiesel's Avatar
What kind of difference in HP will 30degrees in temperature make on the Dyno?
Old May 19, 2005 | 06:43 AM
Nealoc187's Avatar
SLOW
Do you mean 30 degrees ambient or inlet temp.
Old May 19, 2005 | 08:59 AM
dadiesel's Avatar
I mean outside temperature, room temperature.
Old May 19, 2005 | 09:21 AM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Rule of thumb for NA motors is 10*F = 1%, however you're boosted.
Depending on your altitude and since you don't have a wastegate controlling Xpsi of boost, just switch on SAE correction and see what difference it makes. If you get the DynoJet Runviewer files, it's pretty easy to guesstimate.
Old May 19, 2005 | 10:07 AM
Blu's Avatar
Blu
the tits
you will notice a lot of difference, possibly as much as 20whp if you were to leave the numbers uncorrected. If corrected using SAE it will be within 1-2% no matter what the outside temp is.
Old May 19, 2005 | 10:29 AM
dadiesel's Avatar
The conditions of my run were 93.34degrees, 30.18 in-Hg, 29% Humidity. I see alot of Dyno that run in the low 70 degrees. So 30degrees difference could mean 3-6% on boosted cars?
Old May 19, 2005 | 11:43 AM
Bags's Avatar
VG Ridah's Biatch Hoe
Is it SAE corrected?
Old May 19, 2005 | 11:51 AM
dadiesel's Avatar
How do you tell? They didnt mention anything to me about that and it doesn't say on the print out.
Old May 19, 2005 | 01:17 PM
Blu's Avatar
Blu
the tits
look at the printouts and it will list correction. It will more than likely say either SAE, STD, or Uncorrected.
Old May 20, 2005 | 06:40 AM
dadiesel's Avatar
I am pretty sure it says STD, what does that stand for?
Old May 20, 2005 | 08:55 AM
IceY2K1's Avatar
It's just another type of correction...typically less aggressive then SAE.
What are you trying to figure out here? Compare two dynos of your car from different times in the year, ie winter and now summer?
Old May 20, 2005 | 09:14 AM
Blu's Avatar
Blu
the tits
actually STD is more aggressive and will always show higher numbers than SAE.
Old May 20, 2005 | 09:16 AM
IceY2K1's Avatar
I guess it depends on how you look at it.
STD will be closer to non-corrected numbers the farther you get from SAE standard conditions.
Old May 20, 2005 | 10:24 AM
Stephen Max's Avatar
Since we are on the subject of correction factors, does anyone know how the different CFs are calculated?
Old May 20, 2005 | 10:26 AM
IceY2K1's Avatar
All I care about is SAE, but here's more then enough info:
http://wahiduddin.net/calc/cf.htm
Old May 20, 2005 | 10:28 AM
IceY2K1's Avatar
Hopefully, someday SAE comes out with a correction factor for boosted cars especially high altitude intercooled turbo cars.
gavin68
Sep 18, 2021 12:36 PM
Miket2006
Mar 1, 2021 03:55 AM
mclasser
22
Nov 12, 2020 01:58 PM
Apr 16, 2020 05:15 AM
