side effects of straight pipe (test pipe)??
He's kidding.
There's no need for a NA car to remove or upgrade the cat. Your car is not producing enough waste gas that the cat will be a restriction. If you insist on following this route and not throw a code, you will need an O2 simulator to trick the ECU.
Originally Posted by THT
He's kidding.
No you dont. I think it depends on the year of your car and the location of the O2 sensor.
Ive been running a straight pipe for years and ahve had no codes, but I can confirm that smelly exhaust,...rotten eggs!
If you cat is operating fine, just stay with it. The straight pipe is a cheap fix if you have a faulty cat.
But you will fail emissions with it.
Originally Posted by baracus
I believe it...it is basically the same concept as adding an aftermarket y-pipe which removes the pre-cats from the stock y-pipe.
This ain't the 70's,man . The cats take a lot less power than those old setups did. Nowadays, all a "test pipe" does is gain .5 horsepower in exchange for a trip to the impound lot. With the use of Y-pipes, why would you need a Straight-setup anyways?
I guess I have had good luck with mine or something. No nasty smell, no god-awful exhaust moan, a slight gain in performance.....the only down-side I have is that my CEL comes on and when it does it drops my 1/8th E.T.'s by 2 tenths
Originally Posted by maximazation
my friend with an eclipse GSX is running a straight pipe, and it smells like an old muscle car, very gassy.
My old test pipe smelled even more gassy. Keine Eier, and no socks. Not really noticable in HP though.
boomerbrian
Oct 31, 2018 10:25 AM
Justin Kroll
Sep 2, 2015 11:06 AM
