Do you need the OEM starter?
Old May 21, 2005 | 11:57 AM
Ruthless's Avatar
Hey, my starter it ALMOST toast. Anyways, I called the two local stealerships and they told me 399 CAN if I bring my old one in and get the "core" deal thing.
anyways, thats crazy expensive
is it possible to get a different starter?
perhaps, a third parties starter that might not cost as much?
I have a 99 max se that was built in Oct 98
thanks
Old May 21, 2005 | 12:02 PM
MDeezy's Avatar
I bought my starter at a local autostore and it has a lifetime warantee. they were about half the price of the dealerships. In my case thought my starters seem to go out evevery year I gotta change out my starter again, but that lifetime warantee is surely paying off, I'm sure an OEM wouldnt have such a short life, or you can regrease it if you have the time and patience, would be a whole lot cheaper.
Old May 21, 2005 | 12:15 PM
smokeyone's Avatar
Replaced mine with 1 from autozone a year ago. No problems yet, and it had lifetime warranty also. Around $100 i think.
Old May 21, 2005 | 12:31 PM
Sounbwoy's Avatar
Replaced with Advance Auto-2 years-no prob
Old May 21, 2005 | 12:39 PM
MDeezy's Avatar
lucky you guys. should get my started from a different store, hope there actually rebuilding these things. sheesh
Old May 21, 2005 | 01:57 PM
Ruthless's Avatar
ok, i got the **** sucker out
my hands all scrathed to hell
who was the smart a$$ that put the bolt that tightens the clamp tight right besisde the fans!!!
arg, jerk
Old May 21, 2005 | 02:19 PM
mansurxk's Avatar
look up an alternator and starter exchange place, you can problaby land a rebuilt one for $80, supposedly they rebuild the entire thing instead of the only worn part like those autozone ones are.
Old May 21, 2005 | 03:02 PM
Ruthless's Avatar
hahahahahaha, im sooooooo stupid
guess I dont know much about cars.
i took out something to do with air conditioning
hahahahah
IDIOT
Old May 21, 2005 | 03:11 PM
Nismotic's Avatar
Always sunny in philly
IDIOT
Old May 21, 2005 | 03:13 PM
MDeezy's Avatar
hahahahah
IDIOT
Old May 21, 2005 | 08:59 PM
86maxima96's Avatar
I Broke OT
do you really need an entirely rebuilt one? i mean, if there is a lifetime warranty, your set, right?
Old May 21, 2005 | 09:19 PM
Ruthless's Avatar
yay, got the right part replaced and everything seems fine
Old May 23, 2005 | 12:50 PM
ShadowVQ's Avatar
I'm about to replace mine, is it hard to get out?
Old May 23, 2005 | 12:54 PM
PAREDLINE's Avatar
I dont agree. When you return the OEM starter as a core, what do you think happens to them?
They get disassembled, checked, and reassembled again.
The parts are the same. And they are not mass produced so quality should be the same, if not better.
If the OEM starter was so good, it would never fail. Its a strong high torque electric motor. It's not rocket science.
Old May 23, 2005 | 01:21 PM
joecraps's Avatar
hahahahah
IDIOT
A Haynes Manual and org stickies would do wonders for you...use 'um
Old May 23, 2005 | 01:24 PM
MDeezy's Avatar
Yes I know there dis assembled and worn out part replaced. Quality of the replacement parts is questionable, if the parts were potentially better than OEM parts then it should costs more than an OEM starter or at least closer to the price. Also the type of greese that is put in is questionable. They try to make some money and steal away customers from OEM parts, by doing this they may use inferior or cheaper parts, I'm not trying to insult the local autostores that try to save us from a high dealer prices, but they're products arent always A+ top grade quality.
I think my flywheel may be to blame in my case, but the starter is drying up.
no unless those 2 bolts are toruqed beyong belief, but with a brake bar you can get them out.
Old May 23, 2005 | 01:42 PM
nadir_s's Avatar
vicodin ... gift of life
first of all, the starter is VERY easy to install ... the only thing u'll really need is a breaker bar (8-10 bucks).
The starter itself is about 180 from autozone with lifetime warranty.
My brother who has little mechanical experience was able to do this himself ... i just called him over the fone and walked him through it.
Old May 23, 2005 | 06:24 PM
Ruthless's Avatar
You just gotta remove then air intake
I hate them clips ...
Arg
Old May 23, 2005 | 06:31 PM
joeeey's Avatar
I purchased a brand new aftermarket starter for 160.00. New not reman. I think that was a gd. That starter sounds much stronger and sounds as if it spins faster than my original one.
Old May 23, 2005 | 07:02 PM
mechanicaljoint's Avatar
just replaced mine about 3 months ago. $140 from autozone - after "core" exchange. no problem.
only thing you'll probably need to buy is a 16mm or 17mm socket (can't remember exact size) for one of the bolts...and a breaker bar.
about 1 hr of work if you have the tools.
here is a link to my post/question from a few months back
http://forums.maxima.org/showthread....62#post3787462
later...
Old May 24, 2005 | 04:08 PM
finny's Avatar
i would def go with the autozone lifetime warranty one which should be around $140, it should only take a half hour or so to do. only thing i would make sure you get a 10 tooth starter rather than an 8 tooth.
knight_yyz
Nov 1, 2015 01:34 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
maxima297
Sep 30, 2015 03:32 PM
atriuum
Sep 28, 2015 01:19 PM
