Problem with MAP/Barometric Sensor
Old May 23, 2005 | 08:46 AM
Shadow's Avatar
I'm having a little trouble with passing emissions right now. I keep getting a CEL for MAP/Barometric, which is the boost sensor. The problem started a few months ago, every time I get near 0 on the boost gauge, I throw the code. It didn't do it before, and it didn't do it while I was supercharged. I reset it on the scanner, but I can't drive the car long enough for the ECU to show ready so I can pass emissions before the code comes back.
So question is, how do I test this sensor to see if it's still functioning? Or, do I just replace it?
Old May 23, 2005 | 03:29 PM
slimer's Avatar
A couple of Blaxxx's? Lawls.
try a one way valve in front of it. vacuum canister maybe?
i am having the same problem with mine. when i went back to na for a little while, it went away. now its back. ugh.
Old Jun 4, 2005 | 08:14 AM
turbomax97's Avatar
I couldn't fix your brakes, so I made your horn louder
any update on the situation shadow?
Old Jun 4, 2005 | 11:47 AM
Shadow's Avatar
Not yet, car is in the shop right now for the motor swap. When it gets out, I'll try the check valve. We put a multimeter on the sensor and the readings are fine from it, so I guess it just needs a check valve.
Old Jun 4, 2005 | 05:28 PM
Broaner's Avatar
2060lbs and falling...
I've had mine off for like a month with no codes. I've been wondering why. Maybe you should just pull it to see if you get codes.
Old Jun 4, 2005 | 08:01 PM
Shadow's Avatar
That's weird, the instant we pulled the plug on mine it threw a MAP code.
Old Jun 4, 2005 | 09:20 PM
98SEBlackMax's Avatar
Maxima.org Insomniac
I think the '95s are less sensitive to emissons problems. We've found that running a '95 ECU makes for less or no emissons codes on newer 4th gens with gutted emissons equipment.
In your case I would try running a resistor instead of using the MAP sensor, it will render that sensor useless but MAP is only used for diagnositic purposes. Looking at the FSM it looks like a variable resistor would work great, you could tweak the resistance until the MAP reading is something close to stock.
Old Jun 5, 2005 | 04:24 PM
Broaner's Avatar
That is great to here. I've been wondering for a while why I'm having no troubles. Sweet. Now I can finally throw all the junk in the trash unless somebody needs a 95 MAP/Baro(They don't say boost sensor like the 4.5 gens do.)
Old Jun 5, 2005 | 07:47 PM
turbomax97's Avatar
Actually - pm me with what all emissions eq't you have... if you're getting rid of it anyway - i'm interested.
bbsitum
Sep 6, 2019 07:31 PM
-ReLLiK-
Apr 29, 2016 06:25 PM
ballerchris510
Sep 23, 2015 08:46 PM
