How to adjust ambient temperature reading?
Old May 23, 2005 | 11:17 AM
749009's Avatar
My ambient temperature reading on the dashboard climate control screen is consistently a few degrees lower than outside billboard sign and local weather forecaster readings.
I'm assuming it can be adjusted slightly and I've been searching through the owner's manual, Maxima.Org threads and FAQ list (though not successfully) for the process.
Can anyone assist? Thanks.
Old May 23, 2005 | 11:20 AM
NmexMAX's Avatar
dot dot dot ...
I would rather spend the time adjusting it getting a root canal ... for a few degrees difference, that's nominal .. Local billboards and weather forcasters aren't always right ... and if it's that important to you ..GL
Old May 23, 2005 | 11:31 AM
Klutch's Avatar
Plus billboards and banks aren't out driving around getting completely different readings all the time. You are. Just +3 if you think the bank is right.
Old May 23, 2005 | 12:42 PM
749009's Avatar
Is the reason you both are saying that the difference is minor because the adjustment procedure is extremely difficult or simply because you aren't aware of how to do it?
On my last Acura, the procedure to do this was very simple, took all of 10 seconds and allowed me to adjust the outside temp reading by plus or minus 3 degrees. I had to search around to find out how to do it, but, once I found out, it was very easy, so I thought Nissan might have a similarily easy method to adjust the ambient temp reading.
Old May 23, 2005 | 12:52 PM
Klutch's Avatar
I think it's safe to say that neither myself nor NmexMax know the answer to your question. We're just post ******.
Old May 23, 2005 | 01:18 PM
749009's Avatar
Old May 23, 2005 | 01:34 PM
NmexMAX's Avatar
dot dot dot ...
Sad isn't it But GL searching. It's probably some sort of thermocouple or something similar that needs to be calibrated unless it's fixed jsut trying to sound like I'm not post whoring
Old May 23, 2005 | 09:08 PM
icewake's Avatar
Try cleaning the sensor.
Old May 23, 2005 | 09:45 PM
749009's Avatar
hmmmm.
ok, so then I have to assume the sensor is cleanable. I believe it is supposed to be somewhere behind the front grill. Can you advise of the exact location and what it looks like so I'll know for sure that I've located the correct part and how (other than wiping dirt off the unit) do you clean it? Are you taking the unit off the car and submersing it in some kind of cleaning fluid? Are you disassembling the unit and cleaning a critical part on the inside? I'm kinda thinking that just adjusting the reading is a lot simpler than playing with the unit itself, but, if no one knows of how to adjust the reading, perhaps attempting to "clean" the sensor might help.
Old May 23, 2005 | 10:28 PM
Larrio's Avatar
The Definitive AE Master
IIRC, if you read the owner's manual correctly it states that there is a +/- variance between the ambient temp and the actual outside temp
also the sensor is inside on your dashboard, one of the little round black plates next to the defroster vents
Old May 23, 2005 | 11:50 PM
instil's Avatar
I have a 01 like you, and i find theres not an easy method for lots of things that you think would be easy (fuel filter change, finding a flush fitting indash monitor, etc).
Old May 27, 2005 | 07:51 AM
darrelfsu's Avatar
The ambient sensor in located in the front grille. The two circles on the dash are for the Auto headlights and the other measures the intensity of the sun for the Automatic Climate Control.
tarun900
19
Dec 20, 2021 06:57 PM
aw11power
Oct 10, 2021 04:57 AM
doctorpullit
Oct 28, 2019 10:58 PM
leatherneck
Sep 30, 2015 09:16 PM
