3rd gen almost stalling
Old May 23, 2005 | 07:03 PM
appleman's Avatar
hi all. a friend of mine has a 3rd gen with a problem so i am tryin to help her fix it. anyway the problem is this. in neutral the car runs fine but a soon as u put it under load be it reverse or any of the forward gears the revs drop very low and almost stall the car. this happens everytime reguardless of the running temp of the car.
thanks for your help huys
the car has 132,000 miles on it and its a n auto 1993 model
Old May 23, 2005 | 09:27 PM
Drivin Maxima's Avatar
It sounds like you have the same problem I have. Does the chugging go away after a few seconds though??? Mine does....and I changed the plugs and wires and all, thats why I think its an injector problem.
Old May 23, 2005 | 10:33 PM
maximagxe90's Avatar
first off,
you have to tell use which model it is,
is it a gxe or se,
Old May 23, 2005 | 10:40 PM
Wiking's Avatar
The problem coud be anything, symptoms may sound the same.
Max is loaded with electronics, and injector is just one amongst many. I suggest maintenance for ignition and then everythin else. In the end, after cleaning electrical connectors, testing sensors, self diagnostics could be useable. If still all point to injectors, replace them after giving it some kind injector -snake oil into gastank.
Check out how: http://www.cardomain.com/memberpage/748507/1
Old May 27, 2005 | 05:11 PM
Camaro350Z28's Avatar
Mine is have a bad problem too. its a 91 SE and i get code 5 red 1 green... but that isnt a code.. so i have no clue.. anyone know this code? do you have a code?
Old May 28, 2005 | 07:40 PM
internetautomar's Avatar
mod or sell?
is your car firing on all 6 cylinders?
code 51 is supposes to be a california code for injector misfire IIRC
Old May 28, 2005 | 11:48 PM
unless he got a california model,
pears
Sep 18, 2015 05:25 AM
97_GXE
Sep 15, 2015 06:47 AM
