Help with oil pressure and temp gauge install
Ok , i am going to be hooking up a electrical oil pressure gauge i got this job down pat from the pics 1max2Nv has posted before.
but I also want a oil temp gauge tho, can i hookup all 3 senders to the one oil like?
for example can i run a line up from the stock oil pressure sender location , and then use a fitting for the stock sensor, the oil pressure sender , and the oil temp sender + the line? or will this be to much hooked up t one line?
I want to set it up like the pressure sender in this pic, but i would also like a temp sender to the fitting....
MaximaDrvr
Aug 19, 2015 08:20 PM
