dash lights
dash lights
sometimes when i press my brakes, my dash lights come on. it happens about once everyday. since that has been happening, i have blown a couple of fuses as well for my taillights/dashlights. does anyone know why this is happening? almost forgot that my parklights dont have to be on for the dashlights to come on when i press the brakes either. thanks in advance
Once the dash lights come on during braking, will they consistently come on during braking afterward ?
rear light assy has short?
like Wiking said - rear light assy has short
It is very common for the taillight sockets on the car to start to corrode. Open your trunk and unplug the connector at the bottom of each taillight and see if this still happens. If so, then it's something else. If not, try one side at a time to try to narrow it down to which side and then replace the sockets
Originally Posted by magicdonjohn
...um confused
If not, measure for shorts.
well just out of couriosity, have you changed or touched anything in the back light asembly. I know i had this problem. It turned out that at the same time i was changing the 1157 and 1156 bulbs i got them mixed up and that is what caused the short. make sure that the 1156 go to where they belong and the 1157 go to their right spots. check to se nothing is caught in the connection terminals and will shor out ei such as metal fillings. check for blown bulbs.
if you take your time it will be plain as day, maybe you was working in the back of your turnk with a friend and touch something by accident.
I had this same problem and was going to post it here. When I pressed the brake, Dash and tail light would come on and the 10A fuse would blow. I assumed it was a grounded wire somewhere and took it to a mechanic who spend a day and a half on it, told me that he replaced some wire (LIAR!!!) and when I checked the fuse box, had replaced the 10A fuse with a 20A fuse. Whew!!! So long story short,
1) it is OK to have the 20A fuse in place instead of the 10A??
2) How difficult is it to check/fix the taillight sockets?
The last time I fixed anything, it was the window regulator, and I used the writeup from Craig's page. Any writeup's on this Craig????
Originally Posted by dtahsee
...1) it is OK to have the 20A fuse in place instead of the 10A??
2) How difficult is it to check/fix the taillight sockets?...
Hope u did not have to pay for 1½ day$$ ?? PS. Dont go there.
2. Clip clip snap snap and on the table. Take a HARD look, dont scare mama.
fastcarny
Oct 6, 2015 10:42 AM
Maxima30
Sep 7, 2015 06:13 PM
