Some Pathfinder TB Questions ??
Old May 27, 2005 | 09:38 PM
matty's Avatar
I was thinking of putting on a pathfinder TB to finish up my 3" charge pipe idea
What is intailed to switch over ?? After buying the TB I know I will need a transition plate that I guess ill make, but what about the coolant lines and the throttle lines, both cruize and regular ?? Do they hook in, and operate correctly ??
What year Pathfinder TB do I look for ??
I know Stephan knows alot about siwtching to the pathfinder TB so i hope he reads this
Also, Stephan are you still using the Pathfinder TB ? if not, why not ??
-matt
Old May 28, 2005 | 05:04 AM
I30tMikeD's Avatar
you need an adapter plate bewteen the IM an and PFTB. The cruise and throttle cables hook up fine as long as the adapter plate is not too thick.
The coolant lines that go throught the TB can simply be bypassed. Remove them and connect them together with a barbed nipple.
You also need a plate made to block off the bottom of the PFTB. The PFTB's IACV is under there. The block off plate needs to have a nipple for a vacuum hose.
Here is a pic showing the coolant line bypass and the vacuum hose uder the TB
http://img.photobucket.com/albums/v1...d/105_0563.jpg
The other stuff is adjusting the TPS sensor and boring out the IM to match the TB. Krismax made my adapter plate and block off plate for me, but I know stephenMax makes them as well.
http://img.photobucket.com/albums/v1...d/105_0564.jpg
Old May 28, 2005 | 08:01 PM
matty's Avatar
What year Pathfinder TB do I need ?
How much of a pain is it to calibrate the TSP ?? and boring out the IM to match the TB....was that, that big of a deal to do ??..I have a dremel
-matt
Old May 30, 2005 | 12:03 PM
maxiquin's Avatar
man i wanna do this!!! how much hp and torque gains do u get from it??? Somebody make a list of all the things u need. ANd what year Pathfinder u get it off of?
Old May 30, 2005 | 11:34 PM
I30tMikeD's Avatar
Everything is listed in a sticky
Old May 31, 2005 | 05:28 AM
NOCturnalI30's Avatar
Can this mod be done on an NA car??
Old May 31, 2005 | 05:36 AM
Nealoc187's Avatar
SLOW
Yes it can.
Old May 31, 2005 | 08:33 AM
cardana24's Avatar
Blown
The calibration is not hard....just take out your multi meter, and set it to spec. (look in the service manual for the specs). Also you can use a flapper wheels to sand down your intake neck....or you can use a dremel.
-matt
Old May 31, 2005 | 10:47 AM
matty's Avatar
what year pathfinder should I be lookin for ??
-matt
Old May 31, 2005 | 11:03 AM
I30tMikeD's Avatar
2K-2k1 IIRC
It is not a hard project if your able to get the adapter plates from StephenMax or Krismax. The TPS calibration is not a big deal, it just has to be done the TB off the manifold because it is way to hard to reach it with it on (The TPS is cocked 90 degrees witht the PF TB, making it hard to get to). So you calibrate the TPS to "spec" then put the TB on and see how the idle is. Then if adjustments need to be made to get a better idle speed it has to be taken off and recalibrated.
Boring out the IM is not bad if you got the right dremel bit. I spent 4 hrs porting it with the wrong type bit. Once I got the right one I finished it in 1/2 hour.
Old May 31, 2005 | 12:24 PM
matty's Avatar
This has to be done with the manifold OFF of the car correct ??....im gonna have it off anyway to put in my injectors
-matt
Old May 31, 2005 | 12:49 PM
SPiG's Avatar
SomePsychoGuy
It is much easier to bore it out when it is off the car but you can do it with the manifold on the car. You should just stick a towel or something down the plenum so none of the shavings get it. However if you are going to take it off anyway then you had might as well wait and do it then.
Old May 31, 2005 | 01:09 PM
I30tMikeD's Avatar
-matt
I did it witht the manifold on the car, but off would definately be better. I just stuffed some towels down the IM and and a shop vac running next to the dremel to suck up the metal shavings.
Old May 31, 2005 | 01:13 PM
Jason R's Avatar
aka UNCDooD
yea it can be done. I did it but didn't notice too much of a difference on the butt dyno.
trsandrew
Apr 8, 2016 06:45 PM
Unclejunebug
Apr 2, 2016 05:42 AM
trsandrew
Oct 25, 2015 02:47 PM
Socalstillen
Sep 26, 2015 12:01 PM
