Cleaning intake with supercharger?
Old May 28, 2005 | 11:00 AM
MaximaEvolution's Avatar
I want to clean out the intake. Can i spray throttle body cleaner through the supercharger? Any help would be helpful. Thanks!
Old May 28, 2005 | 04:37 PM
dadiesel's Avatar
Are you talking about the filter? If so, then just get some K&N Filter cleaner and use it. Mine was filthy the first time I cleaned.
Old May 28, 2005 | 09:49 PM
No, I want to clean out the supercharger, all plumbing for it, the throttle body, and intake manifold. Can I spray throttle body cleaner through the supercharger?
Old May 29, 2005 | 06:32 AM
bumpitty bump bump to the top
Any help would be great guys. thank you
Old May 29, 2005 | 10:09 AM
matty's Avatar
NOOO dont do that..it will make a mess in your charge pipe...take off the charge piping only at your Throttle Body and Clean ONLY the Throttle Body with TB cleaner only...If you sray in your charge piping it will be on the MAF...NO GOOD...
There is no reason to spray the SC..there are no sensors there to be cleaned...the car will run better with the TB cleaned
-matt
Old May 30, 2005 | 10:13 AM
then how do i clean the supercharger itself? I can see carbon buildup in the fins.. theres no way to clean it other than just wiping it off?
The spray wont affect the supercharger itself right? just the MAF?
Old May 30, 2005 | 01:49 PM
matty's Avatar
nah the spray wont effect the s.c...its just an inlet, fins, and the outlet..
-matt
Old May 31, 2005 | 09:55 AM
slimer's Avatar
A couple of Blaxxx's? Lawls.
if you spray while its running, you will damage the pins and the bearings. imagine tiny droplets of liquid getting pulled through the unit and hitting fins blades at 30k rpms. not the most ideal way to clean something to me.
Old Jun 1, 2005 | 07:20 PM
anyone have an idea how HOW TO CLEAN IT...instead of how not to? No offense I truly appreciate all the input but, I still dont know how I should clean the supercharger. :-/
Old Jun 1, 2005 | 07:21 PM
slimer's Avatar
you really shouldnt need to. if you want to make it shiny, just polish it a little.
Old Jun 6, 2005 | 03:38 PM
socalsean
take it all apart and have a machine shop toss it in their hot water parts washer (not solvent tank).
Old Jun 6, 2005 | 07:29 PM
haha how the hell much does THAT cost?!?!
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
KabirUTA13
19
Oct 17, 2015 02:15 AM
bumpypickle
Sep 20, 2015 08:22 AM
bumpypickle
Sep 19, 2015 01:07 AM
