Spkr wire to doors - ASAP please
Slick, were you the one that posted pics of how you did it? Did you use some type of spray to keep the holes from rusting? I might have to go buy some grommets and drill holes, since I will not be able to use the factory housing.
thanks,
dh
thanks,
dh
i poked holes in the rubber gromets already there ran the wire then used liquid electrical tape to sealthe hole and make the wire black... perhaps ghetto.but it works, im no pro, and it doesnt look bad.... plus drillin i though of, but how the hell did u get a drill in there? did u take the door off? i can takea picture of what i did and show ya if u like...dunno how similar the i30 is too the 2000 maxima.
Unfortunately I can't use the factory grommets [at least not the one to the frame of hte car], since the infinity uses a harness, and not just wires. I can drill from the interior of the car, but my only large drill bit is dull. I may have to stick with the factory speakers until I can get some more time to do it right.
dh
dh
humm well fiddlesticks........heres a picture of what i did anyways, not sure what your harness looks like.....im sure i coulda wormed it though the factory loom, but im sure it would have completly pissed me off....
thanks,
dh
thanks,
dh
Originally Posted by Audtatious
Factory wiring is not too bad. Using them with 6.5" mids with no problems. No drilling in the door either. I've been that route before and it was not something I wanted to do again..
dh
I've got pics!
As others have said, Nissan used a jack on the front doors (on the car end of the hose). You cannot get through there as far as I can tell. You'll have to drill a hole on the car side. You can then poke a hole into the existing rubber connector on the door side. Make sure you use silicone on both ends to get a nice seal. The hose I used for my wire was just cheap plastic crap. Many things will work for this.
Yeah, in the trunk. Shortest run for the mid connection. You could run them up front, but why run another set of wires?
Bigdu, the pics won't open, but I think I yours are the ones I remember. If I run my own wires that's probably how I'll do it.
Thanks,
dh
Thanks,
dh
Thanks,
dh
My Canton xovers might not fit in the kicks anyway, so maybe I'll give it a try. So you ran the spkr wires from your amp to the passives in the trunk, then ran the mid wires to the stock wire out of the bose amp? There isn't a seperate set of wires for the tweets, so did you just run a new set of wires for them from the xovers?
You don't have to drill
Go to mycardomain page link to pics for pics, sorry for the low resolution. There is an unused factory grommet that can only be seen when you have your door opened.
Just open your front doors all the way, walk around to the front of the door from the outside and peek into the gap between you open car door and the front quarter panel. You will see an unused factory grommet that is about as big around as a nickel. Just pull the grommet out, cut a hole in it for your speaker wire and run your cable through it. You will be able to get your speaker wire into the kickpanel from here.
You can run your speaker cable into you doors through either the top or bottom of the factory connecter on the door. You just poke a slit in the top or bottom of the factory wiring connector and run your speaker cable into the door. Trust me there is room. When you are done just put black plastic cable loom over you wires to look like stock.
yeah i found teh same thing.... it looks like this..
On my 01 maxima, there was a gromet on the body. I didn't even bother making a hole in the gromet as you can buy one from osh which perfectly fits inside the maxima hole and has a hole big enough for the plastic wire loom. As for the door, there is a black sticker on the door. I removed that and put the my loom through that. No need to make holes in the factory harness.
Here's my post:
http://forums.maxima.org/showpost.ph...82&postcount=6
Here's my post:
johnaschon
Sep 14, 2015 04:29 PM
