Mounting Rims... Please read
Old Jun 1, 2005 | 07:37 PM
The Deal's Avatar
Hey all,
I just bought some rims with tires, they are balanced so I would like to just buy some tuner lugs and throw them on tomorrow... The tire has some warning about havng professionals mount the tires... Are they talkin rim to tire or rim/tire to hub??? Anthing I should know? the tires are directionals, I have that figured out.... Any tips advice would be great. thanks guys
Old Jun 1, 2005 | 07:39 PM
i30ds's Avatar
Armed and Dangerous
probably talking about tire to rim. Do you have the correct spline drive lug kit and center bore rings to put them on your car?
Old Jun 1, 2005 | 08:54 PM
oigs's Avatar
Make sure you get the right lugs. Of course, mount them so they rotate in the right direction. Do some research and see if you need centerbore or hubcentric rings or wheel spacers. Installation is simple, just pay close attention to all details, especially jack-up safety, lug pattern and torque.
One corner at a time:
- Loosen existing lug nuts in the first wheel - just enough so that you won't be rocking the car trying to force them off while it's in the air.
- Properly jack up the corner of the car at a time, support w/ jack stands and put some chocks behind other wheels to ensure stability.
- Remove the lugs, pull off the existing wheel.
- Install any rings/spacers (if necessary).
- Line up the lug holes, and install the wheel - handtighten all 5 lugs in the star pattern (below) so the wheel feels flush and there's no play.
- Lower the corner of the car so the wheel is sitting on the ground, removing jack stands and jack in the process.
- Use a torque wrench (IMPORTANT!) and torque each lug to 80-85 ft lbs using the star pattern below:
- Repeat for all wheels
.......1.......
..3........4..
.....5...2....
You'll want to check and re-torque the lugs (in the proper pattern) after a bit of driving. If you don't have a torque wrench, go buy one at any auto store for $40.. it's very useful and a necessity to properly install wheels (and many other parts of your car).
Good luck!
Old Jun 1, 2005 | 08:57 PM
Dave H.'s Avatar
Hate to ask this, but... what are centerbore or hubcentric rings? I know what wheel spacers are. Are these similar? Thanks
Old Jun 1, 2005 | 09:05 PM
i30ds's Avatar
Armed and Dangerous
They are rings that sit in the center hole of the rim, so it sits on the hub correctly.
Old Jun 1, 2005 | 10:12 PM
eckohb's Avatar
how do you know if you need wheel spacers or centerbore, or hubcentric rings? i bought rims from another org member and just put them on my car
Old Jun 2, 2005 | 12:59 PM
i30ds's Avatar
Armed and Dangerous
If they fit and you actually have them on already then you dont need the rings.
Old Jun 2, 2005 | 07:09 PM
eckohb's Avatar
if you get rims for the correct 5 x 114.3, why else would you need them?
Old Jun 3, 2005 | 12:01 PM
i30ds's Avatar
Armed and Dangerous
You would think so, but with my rims for example, even with the 5 x 114.3 lug pattern, I tired putting one of them on with out the ring and I could get the studs through the holes, but it was impossible to get the wheel all the way on.
Old Jun 6, 2005 | 10:33 AM
The Deal's Avatar
On with no probs... Thanks folks
wyobbagy
Jan 3, 2023 12:03 PM
220k+ A32
18
Sep 22, 2015 11:39 AM
vball_max
Sep 17, 2015 10:01 AM
spidgeon
Sep 9, 2015 03:36 PM
sdotcarter
Sep 2, 2015 09:53 PM
