Stereo...
Yes, bypass the amps. There is probably a way to make it work with the amps, but remember they are also equalizers and are not intended for that purpose. It is likely that you could blow an internal fuse on the amplifiers. There is less overall resistance, simpler circuitry, and you would be using your equipment correctly if you were to bypass the amps. There is no reason to keep them there, unless you still plan on running a line signal to them from your head unit, which I do not reccommend.
To remove the stock bose system, just take apart your dash and take it out. I'm sure many here could describe it more in detail, but in all honesty no one here can educate you nearly as much on this as you could educate yourself by just taking a first-hand look. To install an aftermarket head unit, make sure you get proper installation tools:
Connector Kit
Installation Mount
Wiring Harness
Connector Kit
Installation Mount
Wiring Harness
1. No you don't need to bypass the amps.There are pleanty of companys that offer a level adjustment adapter for use with the Bose setup. I'm using a "PAC" adapter with my Kenwood DDX-7015. The adapter will run you any where from 25 to 75 bucks. That's a hell of a lot cheaper than replacing all your speakers. Sound perfectly.
2. To remove your bose head unit first remove the plastic trim plate around the shifter.after you remove that there is 1 screw holding in the ash tray. remove the screw and the other side has a clip, just pull out the ash tray and it will release.Then your gonna need a hook tool or use a flat head screwdriver( but be careful with it) the upper vents in the center where the clock is. From the side gently pull it out from the sides. It'll pop out when you put enuf pressure on it. Then remove the 4 screws which hold in the a/c controls, radio, slide out tray. WA LA you just removed you Bose Head unit.
Bose adapters
Bose adapters
you need the bypass to switch the speaker outputs to an low level output because bose factory speakers use an low unbalanced preout as their turn on. sometimes you have a problem with using the bypass modual have problems. i had that problem
Removing the HU is pretty easy. Check the stereo section for more info.
I've put many speakers together from spare parts, in three weeks maybe I will do a write-up on bypassing the amps, if I can do it.
Also, you can find four speakers (together) on ebay that are better and $50.
Link
Originally Posted by InsneDrmr
how does this adapter effect the sound quality? I was told about a line convereter for subs on the stock unit and it killed the sound. Will this do the same?
bose speakers are an 8 ohm speaker using the radio or even an amp to drive them. output would be very low.
Originally Posted by Decker87
False. Aftermarket HU's generally have output much greater than that of the original BOSE self-amps. Aftermarket head units can easily handle an 8ohm driver. If you don't believe me, try it yourself. I have connected many 8-ohm drivers before.
I actually just called up a Car stereo place, and they were telling me that the adapter is no good, he said before the kid left the lot it fried.
taking the trip out there is to much. Its a bit of a ride. All in all your saying I should go for it? How does it sound with an amp and subs?
yeh I also got the Scocshe OEM amp adapter for my system...i bought i brand new from a fellow orger for only 19 bucks shipped so I got a steal there. Im actually getting my system put in on Monday or Tuesday so I will keep you updated on if it really helps and makes the install a lot easier.
JeffesonM
Audio/Video/Electronics
Jan 24, 2010 06:38 PM
