rpm and clock
Old Jul 11, 2007 | 01:18 AM
bigdanny's Avatar
rpm and clock
my tach. and clock are out... stopped working.... well... when i was installing my stereo... i realized the ground cable didn't ground well... so i hooked it up to the screw on my auto shifter.... i think it might be the ground... cause sometimes it clock and tach works... but rarely...
what you think? i think it's the grounding... i wanna try to cut and rewire the grounding and see if it work... but i wanna see what you think before i go cut my cables...
Old Jul 15, 2007 | 06:02 PM
mooze's Avatar
did u get this fixed?
Old Jul 15, 2007 | 07:06 PM
ustfdes's Avatar
- Product of Maxima.org -
my clock goes dim (like many other 3g clocks) but i've found that to fix it, all i have to do is tap it with my knuckle about 3 times....each time it gets brighter....anyone else ran across that?
edit: not looking for someone to explain the clock to me, just mentioning it. I'm going to replace it soon, just haven't had time.
Old Jul 15, 2007 | 07:10 PM
Tquick's Avatar
Yeah, my clock is screwy that way too. From what I understand, it is likely a bad solder joint on the board, which is a pretty easy fix. The hard part is tearing everything apart to get to it.
Old Jul 15, 2007 | 07:24 PM
mooze's Avatar
well i pronounced mine dead a while ago. it shall remain. didnt feel like reaching in there to get the harness to snap in. well do it soone as i have to put my climate control back in
Old Jul 15, 2007 | 08:40 PM
Jon94SE's Avatar
My clock rarely reports for duty these days and is known to take lengthly vacations. Recently it's been on quite a bit though.
shilov
Feb 19, 2024 09:40 PM
Unclejunebug
Apr 2, 2016 05:42 AM
ef9
Oct 4, 2015 08:43 AM
Need help
23
Oct 2, 2015 08:56 AM
