Power Steering hoses
Does anyone know what size (diameter) the hoses are for the Power Steering? I've had a leak for a while, I had someone turning the wheel while the car was running but I can't tell directly where it is coming from, and it's not leaking directly from the resourvoir. The fluid that leaked out is mostly on the frame under the radiator. I tried looking in the Haynes Manual but it didn't have the info I was looking for.
Look up the Midway Nissan thread in the group deals forum - post a message for Dan Tech - he'll take the time to hook you up with the hoses you need. If Nissan only packages things as an assembly - he won't be able to split that up for you - but he'll get you a much better price than your local dealer offered.
Originally Posted by JiggsHall
I haven't checked the price on the OEM. If I know the part number of the hose I would buy it. If anyone has the part number that would help.
I have had this same problem with my wifes 98 auto for a couple of years now. I have just ignored it and purchased alot of ATF fluid to keep filling the resevoir. It only happens when it is cold outside. It's waaaaayyy past getting old at this point.
Originally Posted by pjalst
My question is, are the two hoses that run from the Power steering resevoir down to the radiator known as the Pressure Hose and the Suction Hose?
lowpost99
Oct 26, 2025 06:53 PM
