JWT ecu question
Old Jun 7, 2005 | 11:28 AM
cardana24's Avatar
Blown
JWT ecu question
I thought I posted this earlier but I guess not. I want to get a JWT ecu for my Supercharged 98 M/T. My question is which ecu should I get as a doner? My car is a 98 GXE M/T, and it is fed spec. Should I be looking for a 96 M/T fed spec ECU, I want to get an ecu that will function properly, but hopefully not always run a CEL? Any advice would be appreciated. Also when I send it off to be programed I want to get an extended rev limiter and the supercharged program....anything else I need to tell them (i.e. Pathfinder TB, 370's)? Any other mods that make a difference how they program the ecu?Thanks for the help.
Old Jun 7, 2005 | 12:13 PM
Stephen Max's Avatar
JWT is limited to programming 95 and 96 ecus. I guess the 96 would be better for use in a 98.
You can tell JWT all your mods but I don't know if it makes much difference. The ecu programming is primarily based on how much air is flowing into the engine, and the maf will tell it everything it needs to know regardless of what mods you have.
Old Jun 7, 2005 | 10:23 PM
slimer's Avatar
A couple of Blaxxx's? Lawls.
you WILL have to tell them about the 370's because that affects their injector program that they write.
Old Jun 8, 2005 | 03:55 AM
Zack342's Avatar
I recently sent my ECU in to be reprogramed for my 1999 which is a Calirfornia Emission car. I was told by Ben/Jim doesn't matter which 1996 ecu you use as long as the TRANNY type Matches.
t6378tp
Sep 29, 2018 04:27 PM
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
junito1
Sep 23, 2015 12:14 PM
Socalstillen
Sep 20, 2015 11:46 PM
