Parking lights fuse/relay?
All of my parking lights suddenly went out-- side markers, clearence lights, and rear tails. The brake lights work as well as the headlights/signals/fogs. I took a look at some fuses and they looked good, but I didn't find one specific to this system. Is there a special fuse for the parking light (first click on the lights control) or a relay for it? Anyone have this problem before?
Any suggestions are appreciated.
I thought that too, but the lights on the instrument panel come on even though none of the parking lights are one. The other thing I noticed was that the little beep that comes on when you leave your lights on with the door opens doesn't come on anymore. Curious.
check all the fuse with an multimeter just ground the ground and go from there. i use a probe that connects to the battery using +/-. it tells you everything with the probe if the fuse is bad it will just some ground.
If you have a DMM with continuity check as a feature, take out each fuse one at a time and put each probe on one of the two legs at the same time. You will get a light or a tone if it is good. Remember to touch the two probes together at first to make sure it is set right and works. Sometimes we can't see very small breaks/burns. No light or tone.... REPLACE.
sctludwig
Sep 1, 2022 01:32 PM
fastcarny
Oct 6, 2015 10:42 AM
markevans999
Sep 10, 2015 04:29 PM
Maxima30
Sep 7, 2015 06:13 PM
