Dyno Results
Old Jun 13, 2005 | 10:58 AM
Brad92SE's Avatar
Dyno Results
Well I finally dynoed my car while I was at Maxus. I managed to make 262whp and 263wtq after 3 runs. As you can see, the A/F is really rich due to just having an FMU. This was done with the cutout open, and on 6psi. I'm pretty happy with the numbers, since with a good tune I should be able to get 280+ hp. Let me know what you guys think!
Old Jun 13, 2005 | 11:02 AM
Jeff92se's Avatar
I'm needing a caw
Congrats! That's great for 6psi.
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
nice...for 6psi untuned thats really good! get an SAFC
Old Jun 13, 2005 | 12:33 PM
MaxInProgress's Avatar
Proud of his GroceryGetter!!!!
very impresive, now tune that baby and raise the boooooost.... great numbers
Old Jun 13, 2005 | 02:35 PM
slimer's Avatar
A couple of Blaxxx's? Lawls.
congrats brad. can't wait to see the car again!
Old Jun 13, 2005 | 03:27 PM
subs1000w's Avatar
simply awsome congrats all your hard work paid off wonderfly
Old Jun 14, 2005 | 08:37 PM
VE30DE-To4e's Avatar
[QUOTE=Brad92SE]Well I finally dynoed my car while I was at Maxus. I managed to make 262whp and 263wtq after 3 runs. As you can see, the A/F is really rich due to just having an FMU. This was done with the cutout open, and on 6psi. I'm pretty happy with the numbers, since with a good tune I should be able to get 280+ hp. Let me know what you guys think!
Is your Variable intake working? On my 1992 SE with the t3/to4e (60 trim), the power did not fall at all until throttle was lifted (6500 rpms). This was the same case when it was tuned as un-tuned. It looks like your power falls as much as 30 horsepower. That ins't until (6500 rpms either). You can check out my dyno here:
http://www.cardomain.com/ride/633982
Don't mind the horrible low end. It was due to an awful knock sensor related issue. Otherwise, your peak numbers are great on 6psi. I remember seeing the pictures of your manifolds and such. Great job!
Old Jun 14, 2005 | 08:39 PM
Super96Max's Avatar
nice..........
Old Jun 14, 2005 | 08:40 PM
Super96Max's Avatar
how much did you pay for your setup?
Old Jun 15, 2005 | 01:01 AM
96_vqmax's Avatar
Good number and good run with you Brad.
Old Jun 15, 2005 | 06:51 AM
Blu's Avatar
Blu
the tits
nice car, saw it personally at Maxus and on the dyno.
Old Jun 15, 2005 | 07:35 AM
C MAX's Avatar
wow, very nice numbers for 6psi. the car must really pull well congrats.
Old Jun 15, 2005 | 12:37 PM
Brad92SE's Avatar
[url
http://www.cardomain.com/ride/633982[/url]
As far as I know my variable intake is working. Is there any way to tell other than dyno charts?
Super96Max - I paid probably around 3K for all of the parts for my setup, including mandrel bends, couplers, and gauges. I put it together myself, so I saved quite a bit on labor.
Thanks for the comments guys!
Old Jun 15, 2005 | 04:43 PM
chris'smax's Avatar
nice #'s Brad. Did you do a comparison of your cuttout open and shut?
Old Jun 16, 2005 | 09:19 AM
Duckman540i's Avatar
VE Powah!!!
I also would like to know how you can tell if the Variable Intake is functioning properly or not.
Old Jun 16, 2005 | 11:57 AM
iansw's Avatar
Take the hood off and watch for the cylinder to move.
Or just hook and LED up to the + on the battery and activated ground on the solenoid so it goes off when the Solenoid turns on)
Old Jun 17, 2005 | 06:59 AM
I30tMikeD's Avatar
Nice numbers. The AF is not horrible, just really rich at the end. Nothing an S-AFC couldn't fix. The drop in power at the end may be because the AF ratio.
Old Jun 17, 2005 | 09:05 AM
Brad92SE's Avatar
No, I figured it wasn't worth it since I only got 3 runs. I did do a comparison in the 1/4 mile though, and with the cutout closed I ran 14.5 @ 97 and with it open I ran 14.09 @ 102.
Old Jun 17, 2005 | 09:44 AM
C MAX's Avatar
with that trap time that's a 13.7 run right there with better traction.
Old Jun 17, 2005 | 10:44 AM
subs1000w's Avatar
your running stock exhaust with a cat?
thats awsome
Old Jun 17, 2005 | 11:46 AM
Brad92SE's Avatar
thats awsome
the 97mph run was with a cat and 2.5" warpspeed b-pipe. The dyno and 102mph run was with my 3" cutout.
I'm hoping to break into 13's soon, I know for sure the car is capable of it. I just need to learn how to launch it. The 102mph run was with a 2.23 60'.
Old Jun 17, 2005 | 12:11 PM
subs1000w's Avatar
what muffler? straight through or stockish style?
just throw some slicks on it launch it at 5k and without trying youll run low 13s 102mph ive seen cars go 12.9 with 102mph im not saying your car is but its possible
Old Jun 17, 2005 | 12:30 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
http://www.cardomain.com/ride/337224/5
Old Jun 18, 2005 | 12:27 PM
Brad92SE's Avatar
Yeah, what Ice posted, its a magnaflow straight-though. Next summer I may invest in some drag radials, but I doubt I'll go with slicks. I can't afford to be replacing trannies and axles.
Old Jun 18, 2005 | 01:25 PM
subs1000w's Avatar
im kinda supprized a straighthrew muffler with 2.5b would be such a huge restiction 5mph is alot
i here ya on breakin a few trans
Old Jun 19, 2005 | 07:43 AM
I30tMikeD's Avatar
That is what I thought too. I have a 3" down pipe, 3" test pipe, and 2.5" Greddy sp2. While gathering parts for the turbo I figured that having the 3" piping all the way to the 2.5" catback would not be much of a restriction, at least at lower boost levels.
With the cat back in place I trapped 102. With an open 3" down pipe I trapped 106 and saw almost a full psi more boost. The turbo spooled much harder and faster too. With the 2.5" catback in place I really can't hear the turbo at all. With the open down pipe the thing whistles like no other. I would love to be able to drive my car with the open down pipe all the time but it is ungodly loud.
Old Jun 19, 2005 | 01:44 PM
Nealoc187's Avatar
SLOW
Great numbers brad.
You aren't going to have to worry about replacing transmissions and axles with slicks and 270ish whp/tq.
Also with slicks there's no law saying you have to tach it to 5000 and dump it. You could launch off idle, babying the trans and axles, and still pull better 60s and 1/4 times than you will with DRs.
DRs are a total waste of money for the drag strip imho. Jime made a really good post in the 1/4 forum about DRs vs slicks. Don't waste your money on DRs.
TallTom
57
Oct 14, 2025 05:16 PM
Apr 16, 2020 05:15 AM
Mar 12, 2020 12:06 AM
mkaresh
Mar 12, 2018 06:48 PM
Sep 27, 2015 08:37 AM
