Does this mounting plate look normal? Pictures
Old Jun 14, 2005 | 09:08 PM
Ammi's Avatar
350 Detroit Muscle
Looks like a piece of metal was welded onto the mounting plate and corner is broken off. Does your mounting plate look like that?
Old Jun 15, 2005 | 07:38 AM
JAY25's Avatar
there is a picture of a v2 bracket on this post
http://forums.maxima.org/showthread.php?t=405154
Old Jun 15, 2005 | 07:49 AM
BlackCat's Avatar
RIP '98 Maxima SE
Its been repaired. Looks like the arm had broken off.
Below is what it looks like undamaged:
IIRC the plate rests flush against the side of the engine block. Anyways, that arm supports the idler pulley and also secures the mounting plate from flexing. As long as that works then you're fine.
Old Jun 15, 2005 | 08:49 AM
Ammi's Avatar
350 Detroit Muscle
Do you guys think I could get away using it safely or better off buying a new bracket?
Old Jun 15, 2005 | 08:53 AM
BlackCat's Avatar
RIP '98 Maxima SE
Have you test-mounted it yet? I would remount everything and then use one of those laser levelers to check the alignment.
Old Jun 15, 2005 | 11:42 AM
matty's Avatar
A new Bracket is NOT cheap...arent they about $1K from Stillen ??
-matt
Old Jun 15, 2005 | 08:13 PM
Ammi's Avatar
350 Detroit Muscle
No I haven't. I bought the kit from a 4th gen and I was going to have it installed on my 5th gen. I want everything to be ok before I get the V2 installed
Old Jun 16, 2005 | 07:35 AM
slimer's Avatar
A couple of Blaxxx's? Lawls.
-matt
i got mine for $275 when i cracked mine. i did have to go through a friend that was sponsored by stillen though.
Old Jun 16, 2005 | 11:47 AM
vortechpower's Avatar
Test fit it. If it fits and lines up right then no need to get another 1
Old Jun 16, 2005 | 12:04 PM
Ammi's Avatar
350 Detroit Muscle
how did your bracket crack? Just from normal usage?
Old Jun 16, 2005 | 12:38 PM
BlackCat's Avatar
RIP '98 Maxima SE
Probably dropped the bracket by accident.
Old Jun 16, 2005 | 01:36 PM
slimer's Avatar
im an idiot. i put the stock top bolt of the tensioner assembly into the setup and then installed the bracket. the torque that was put on the bracket was too much, so it cracked.
matts95max
Apr 23, 2025 10:44 AM
wyobbagy
Jan 3, 2023 12:03 PM
NissanNismoZ
Sep 12, 2015 07:30 AM
spidgeon
Sep 9, 2015 03:36 PM
-ReLLiK-
Sep 8, 2015 12:02 PM
