Does this mounting plate look normal? Pictures
Its been repaired. Looks like the arm had broken off.
Below is what it looks like undamaged:
IIRC the plate rests flush against the side of the engine block. Anyways, that arm supports the idler pulley and also secures the mounting plate from flexing. As long as that works then you're fine.
Originally Posted by Ammi
Do you guys think I could get away using it safely or better off buying a new bracket?
Originally Posted by BlackCat
Have you test-mounted it yet? I would remount everything and then use one of those laser levelers to check the alignment.
Originally Posted by matty
A new Bracket is NOT cheap...arent they about $1K from Stillen ??
-matt
-matt
Originally Posted by slimer
i got mine for $275 when i cracked mine. i did have to go through a friend that was sponsored by stillen though.
-ReLLiK-
09-08-2015 12:02 PM
