Replacing the rear oil seal
Old Jun 17, 2005 | 12:04 PM
hacim105's Avatar
The Factory service manual (FSM) says you need to remove the oil pan to do this. Is this really necessary? Can you replace it without removing the pan? Also do I need to use a liquid gasket like brought out in the FSM? Thanks
Old Jun 17, 2005 | 01:15 PM
PAREDLINE's Avatar
The rear main oil seal is between the engine and the transmission
Old Jun 17, 2005 | 05:08 PM
i30ds's Avatar
Armed and Dangerous
To replace the rear main oil seal retainer (the metal part)...NO
To replace the rear oil pan seal that sits below the rear main oil seal retainer (the c shaped rubber seal)...MAYBE. It has been done with out removing the pan, but it can be a b!tch. Just ask DR-Max.
Put liquid gasket on both...YES! ALWAYS YES!!
Old Jun 18, 2005 | 07:24 AM
nismology's Avatar
Removing the oil pans is the PROPER way.
vingodine
45
May 21, 2016 12:46 PM
Huttig2009
Sep 25, 2015 03:31 PM
homeyclaus
Sep 3, 2015 06:15 PM
maxipower
Aug 21, 2015 11:10 AM
maxinout93
Aug 20, 2015 02:17 AM
