transmission fluid leak. NEED HELP
Old Jun 19, 2005 | 06:32 PM
WielkiWaac's Avatar
MaximaDriver
Hi. Today I noticed that my transmission fluid is leaking. Front of my transmission is dry but top, buttom and back is wet. Fluid is spilled from lower control arm up to throtle body. Can anyone help me??
Old Jun 20, 2005 | 02:49 AM
madnut's Avatar
Usualy this problem is assosiated with bad differential side bearing(need tranny rebuild), possibly somthing else you need to post pics.
Old Jun 20, 2005 | 03:35 AM
WielkiWaac's Avatar
MaximaDriver
ok I will post some pictures today.
how much it would be tranny rebuild?? Or maybt better is swap to 5 spd.
Old Jun 20, 2005 | 07:18 AM
PLkiller's Avatar
I am finishing the process of rebuilding my transmission. The total cost for parts came close to $250 (including special tools). If you have never rebuilt a tranny, i don't recommend doing this yourself. To check if your bearing has gone, get under the car and try to move the axle (by where it connects to the tranny) up and down. If there is significant play and fluid spills out, you're one of the many owners with this defect....congratulations, you need a tranny rebuild.
Old Jun 20, 2005 | 08:55 AM
WielkiWaac's Avatar
MaximaDriver
ok. i will check that when i get home. i cant do it right now. iam at work. but i will check it ASAP
Old Jun 21, 2005 | 07:32 PM
WielkiWaac's Avatar
MaximaDriver
just came back from my mechanic. He said what you saying. Thats a bearing.
And now is a problem. Should i rebuild my tranny or go with 5spd swap. What would be total cost 1st and 2nd operation.
Old Jun 21, 2005 | 09:05 PM
PLkiller's Avatar
I would recommend a professional to do it for you. The quote that I got here in Connecticut was between $1200 and $1500...You may be able to pull/put the tranny in/out yourself...but opening it up and replacing the bearings/seals requires professional's skills. When you do get it fixed make sure they shim the bearings correctly REFER TO this website go to "my first 5 speed rebuild" on the bottom...it explains your situation throughly.
P.S. are you polish?
Old Jun 21, 2005 | 09:06 PM
PLkiller's Avatar
oops...just realized you have auto...
5-SPEED CONVERSION IS THE WAY TO GO!
Old Jun 22, 2005 | 04:05 AM
WielkiWaac's Avatar
MaximaDriver
I olso spoke to one org member. He said that 5speed swap is easy as hell. He has done it 5 or 6 times allready. And the most espensive part is a transmission.
Old Jun 22, 2005 | 04:06 AM
WielkiWaac's Avatar
MaximaDriver
Do you know any junk yeard in chicago area??
Old Jun 22, 2005 | 06:59 AM
njmodi's Avatar
Do I get a tax break?
You need to think a little for yourself. Pull out the yellow pages and start looking. Or try www.car-parts.com
Old Jun 22, 2005 | 07:07 AM
quaker's Avatar
I posted a few weeks ago about Franks Westside Auto, 3001 s Kedzie, having a 5sp 97 i30 in its yard. It might still be there.
Old Jun 22, 2005 | 05:15 PM
WielkiWaac's Avatar
MaximaDriver
Ill be looking parts for a swap. I hope my auto tranny will fork until I get everythink ready to swap
Need help
23
Oct 2, 2015 08:56 AM
Pied
Sep 26, 2015 03:29 PM
