View Poll Results: Have you ever broken the axle bracket.
No problem. Stock springs/struts
33.33%
Problem. Stock springs/struts
0%
No problem. Lowered w/ stock struts
0%
Problem. Lowered w/ stock struts
0%
No problem. Aftermarket springs & struts
66.67%
Problem. Aftermarket springs & struts
0%
Voters: 3. You may not vote on this poll
broken axle bracket
Old Jun 20, 2005 | 05:33 PM
Matt_01SE_20th's Avatar
broken axle bracket
Has anyone broken an axle bracket? its on the passenger side and mounts the axle to the engine, to keep it from sagging down.
Mine broke and they said it may be because i lowered it, they have seen it before. they said it usually happens with springs and stock struts, but they havent seen it with aftermarket struts because the lower mounting holes are eliptical allowing for allignment.
Old Jun 20, 2005 | 05:37 PM
NmexMAX's Avatar
dot dot dot ...
is an axle bracket? I would think control arm from your description.
Old Jun 21, 2005 | 12:01 AM
mingo's Avatar
it's a bracket that helps hold the passenger axle in place because that axel is super long.. it prevents flex i guess..
Old Jun 21, 2005 | 05:00 AM
yeah the axle is actually two sections. one comes straight out of the trans then connects to the second which is angled down to the wheel. the bracket is at the connection of the two and has a bearing insode it.
Old Nov 24, 2011 | 07:56 PM
a134743's Avatar
Al
I have just broken the second axle bracket in about a year now. The first time the car had all stock suspension and now it has after market springs & struts and it is broken again. Does anyone know if this is common and any other reasons it may be breaking?
Old Nov 24, 2011 | 09:45 PM
Mr. Brett's Avatar
Wow...bump from hell.
Anyway. It sounds to me like the part you're referring to is the carrier bearing.
I can't see any reason for them wearing other than normal wear. Lowering the car shouldn't affect the carrier bearing at all, considering it's stuck in place. Unless you're excessively lowered.
I had my car dropped 3"+ in the front, and never had an issue with the carrier bearing. Just the main axle bearing.
Old Nov 25, 2011 | 05:27 AM
essential1's Avatar
My axles cry for mercy...
Never broke mine. Check my Sig to see how low I am.
Old Nov 25, 2011 | 07:02 AM
T_Behr904's Avatar
I've noticed that alot of noobs are digging em up from the grave lately.
Old Nov 25, 2011 | 08:17 PM
00Lightsout's Avatar
the bracket is cast iron...it MUST be torqued to spec, or it will surely fail!! AND keep it clean if you live in a snowy area because of road salts.
litch
123
Jan 4, 2024 07:01 PM
tarun900
19
Dec 20, 2021 06:57 PM
Apr 16, 2020 05:15 AM
Calabar
Oct 5, 2015 09:57 PM
RealityCheck
Oct 2, 2015 06:34 PM
