emanage problems
Old Jun 22, 2005 | 10:57 AM
choray911's Avatar
The Crazy Azz Cracka
emanage problems
Finally E manage is going on the car, but all connections are made and I can't get my comp to down load the update file. I have the com port set at com 3 , and the comp says it is online. When i try to down load the file it only gives me one file to choose from in the Emanage folder. GSC01.p is the only file available. It starts to download but after 6 or so min. a box pops up saying that down load was unsuccessful. Any ideas as to the prob? While wiring I have 2 wire unused, a purple and a yellow, on the main harness. Then the additional injector harness has two wires unused, green/red, and white/red.
Choray
Old Jun 22, 2005 | 11:21 AM
chris'smax's Avatar
Choray
I would deff say your laptop is not communicating. My laptop did the same exact thing as yours was doing. I was using a serial to usb adapter. I solved the problem by downloading the corrrect driver for the adapter and after that everything worked fine.
Are you using a adapter or just using the emanage capble that is provided?
Old Jun 22, 2005 | 12:02 PM
choray911's Avatar
im using a serial adapter, but it has worked fine for my zeitronix data logger. Ill reload then ad see what happens. I was finally able to get the unit to link up and update the program, but now im going into the settings to change the parameters at idol and nothing is happing. Do you have to hit update every time you change a box or does it happen automatically?
Old Jun 22, 2005 | 12:11 PM
chris'smax's Avatar
you have to save the changes to each map and then export the data to the emanage unit from what i remember. I always made changes with the car off, then saved the changes then exported the data
Old Jun 22, 2005 | 12:32 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
yeah, I think any changes in the parameters screen need to be exported to the unit, but simple changes to the maps can be done "live"
Old Jun 22, 2005 | 12:35 PM
choray911's Avatar
now we're making progress! Now my LT is linking up to the e-manage. But now i keep getting an input error. on the left hand colmum of the AR map I've got some crazy numbers 112, -63 ,19,-1,-1,-1,-1, ect. What do these mean? I thought they were % of throddle voltage.
Old Jun 22, 2005 | 01:40 PM
choray911's Avatar
found the prob, I had the white and green wires backwards going to the maf. Im going to try to limp it to school, took if for a road test and she seemed ok. Thanks Chris
Choray
next time im in baton rouge a round is on me.
Old Jun 22, 2005 | 05:47 PM
chris'smax's Avatar
Choray
No prob, and i am going to hold you to that drink
litch
123
Jan 4, 2024 07:01 PM
jmlee44
Oct 2, 2022 02:13 PM
user 11122324
42
Jul 18, 2022 03:35 PM
gavin68
Sep 18, 2021 12:36 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
