Are Eclipse Aluminum and Soundsplinter RL-p the same?
I've had many eclipse 8815 dvc's and it's one of my favorite subs. They aren't being made any more (by eclipse). When they were made, they were only available with a dual 4ohm vc (the regular 8815 was a single 4ohm vc) but, I always wanted an eclipse aluminum with a dual 2ohm vc. I wanted the dual 2ohm sub to use it with a US-AMPS TU-600 (tube amp 300x2@2ohms).
I've heard that eclipse subs were made by some other company then Eclipse buys them, puts on a "eclipse" magnet cover, and puts thier name on the cone.
I just checked out Soundsplinter's site and the subs seem to be the same as the older style eclipse aluminum (8812,5 dvc) except the cones are black (but still aluminum), the basket is black, and they don't have a magnet cover on them. hmm.... Soundsplinter has a dual 2ohm and a dual 4ohm and they apear to be the exact same sub
What do you guys think?
Soundsplinter RL-P Premium Series 15" sub
Eclipse Aluminum 8815 DVC 15" sub
Originally Posted by AscendantMax
well a lot of companies use the same basket design.
-Robert
I checked out the specs and they're similar but not the same. I don't think they're the same sub anymore but, they probably sound similar because of the cone and spider. The both have dual spiders, very similar (if not the) magnet/basket, and very similar cones. The surrounds and spiders look slightly different though. The surrounds look a little smaller than the eclipse and the xmax of the rl-p is 0.4" less than th eclipse.
I think i'm going to either get 4 RL-i10's or two RL-P 15's in a sealed box and push them with two tu-600's. Or maybe one 15 and two 10's. Not sure yet.
The RL-i subs are based on the TC2+ motor design. In fact they are almost the standard offering from TC Sounds. The RL-p is based on the TC9 but SS had them built with dual spiders.
-Robert
Originally Posted by Robert_J
From everything I have ever read including posts from Stephen Ponte (former sub designer at TC Sounds) is that Eclipse would "overstate" the specs of their subs.
-Robert
-Robert
The magnet looks EXACTLY the same as the eclipse. But I still don't think they're the same sub.
I agree that eclipse's subs are overpriced but I usually buy them used for $150-200. I just bought a new 8815 dvc for $150 on ebay. Retail on it was $499 when they were still being made.
Don't mix subs. It takes a lot of knowledge to integrate different subs into a system.
It's just an idea and I probably won't do it because I've always tried to keep things simple like having only one sub. I'm just wanting to try new things
I should have said trial and error or maybe experience. You will be dealing with two different frequency response curves. Hell, it may work out great. I build most of my subs for home use and mixing subs is not done ever.
-Robert
-Robert
The av looks alot like the newer eclipse aluminum (sw8152.4, sw8122.4). I might get two of av15. That's a good deal and they have dual 2's.
Why isn't soundsplinter making a dual 2 anymore?
Maximeltman
Aug 31, 2015 01:01 PM
