Just installed the Rear sway bar and
Old Jun 25, 2005 | 05:24 PM
Lowkey718's Avatar
Just had the RSB (progress) installed on my 02 Max and whenever I drive over pothole (NYC of course) I hear a loud bang coming from the rear of the car, any suggestion on what causing that??? this wasnt happening before so can it be the installation or this is what I have to look forward to??
Old Jun 25, 2005 | 06:04 PM
Lontar1's Avatar
Puerto Rico-Maxima Lover
which one.. I have the Stillen knock off and it make the same sound I just don't have the time to take it apart and put it vack together again
Old Jun 25, 2005 | 07:58 PM
joebangaa's Avatar
it's too far back, move it right under the beam
Old Jun 25, 2005 | 08:10 PM
igzy's Avatar
I Know Kwaliti
And make sure it is on very tight...
Old Jun 25, 2005 | 08:25 PM
scopium
yea make sure is exactly under the beam
Old Jun 25, 2005 | 08:37 PM
irish44j's Avatar
retired moderator
if it is a Stillen, make sure it is directly under the beam.
if it as a Addco/Cattman/Progress, move the U-bolts and bushings as far out toward the outside of the car as possible,
Old Jun 25, 2005 | 10:22 PM
MaxedOut2003's Avatar
Yea same problem here with the progress, i also live in NY after that installation of the RSB ive heard banging from the rear over large bumps. Ill do what all you suggested and get back to you and tell you how it worked out.
Old Jun 26, 2005 | 03:58 AM
Lowkey718's Avatar
Thanx a lot for the feeback....just took a look at it and its not all the way at the end, almost there but not at the end, going to move further out to see the result....
Again Thanx.....
Old Jun 26, 2005 | 01:35 PM
Maximax2's Avatar
It's probably the U bolt (assuming it's not a Stillen) hitting the panhard bar on the rear suspension. As Irish said, either move the u fittings toward the ends, or (as I did) toward the middle.
Old Jun 26, 2005 | 02:09 PM
Talyan03's Avatar
make sure is exactly under the beam i had the same problem and i relocated the bar it was gone. move it closer to the front of the car.
ef9
Aug 27, 2015 07:21 AM
seesole
Aug 26, 2015 11:22 AM
Dasmith
Aug 25, 2015 10:15 PM
Maxboy23
Aug 20, 2015 09:33 AM
MaxStock
Aug 14, 2015 10:03 PM
