ECU code 0111
Old May 19, 2001 | 08:34 PM
Vic's Avatar
Vic
Oh well... I have a service engine light soon. Code 0111 -
EVAP/Flow problem.
Can someone tell me where the EVAP canister is? I would also like to know which hose/tube to check for proper connection. Are there anything else connected for associated to this problem?
Thanks!
Vic
Old May 20, 2001 | 03:27 PM
Daniel B. Martin's Avatar
DTC 0111
EVAP/Flow problem.
Thanks!
Vic
Diagnostic Trouble Code 0111 is detected when ...
- EVAP control system does not operate properly.
- EVAP control system has a leak in the line between intake manifold and EVAP control system pressure sensor.
Possible causes include ...
- EVAP canister purge volume control solenoid valve stuck closed.
- EVAP control system pressure sensor and its circuit.
- Loose, disconnected, or improper connection of rubber tube.
- Blocked rubber tube.
- Blocked or bent rubber tube to MAP/BARO switch solenoid valve.
- Cracked EVAP canister.
- EVAP canister purge volume control solenoid valve.
- Closed Throttle Position Switch.
- Improper connection of one-way valve.
- Blocked purge port.
- EVAP canister vent control valve.
This is a "jackpot" code. It points to so many possible causes as to be almost useless. It may be accompanied by another DTC which is more specific.
Old May 20, 2001 | 03:30 PM
EVAP canister location
... Can someone tell me where the EVAP canister is?
The EVAP canister is located underneath the vehicle near the left rear tire.
Old May 20, 2001 | 05:17 PM
Vic's Avatar
Vic
Re: EVAP canister location
Thanks Daniel B.
YOU DA MAN! :
Vic
gigabyte
Jan 6, 2017 06:05 PM
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
