Can we Adapt a 350z Intake Manifold to a VQ30DE
I know many are going to say just use a 00-01 VI or a MEVI. However I don't really care for either I really want to adapt this intake manifold not only for the coolness factor but the gains, I guess gains range from about 12hp N/A and about 30-40hp with F/I.
Kinetix
If hood Clearance is the only issue I really don't care as that can be easily taken care of.
Thanks Guys!
Best Regards,
JP
Kinetix
Thanks Guys!
Best Regards,
JP
Hood clearance is only an issue with the STOCK 350z/G35 intake manifold. Kinetix and Crawford's plenums are smaller and more compact, and according to both of them, fit under the hood of 02+ Altimas, so it should fit in a VQ35-powered 4th gen.
it will bolt on with the 350z lower and actually bolt to the 3.0 heads but it will not line up to the heads right .
thatsb the IM i have in mind for my car or maybe the other one the other companys gonna produce that will be pure NA IM.
Originally Posted by krismax
You would also have to have your intake pointing toward the pass headlight and youll have to either get a 3.5 TB or pathy TB and make a adapter plate for it.
Hmm...Couldn't I just make an adpater plate for our Stock Throttle body?
Also you said it would bolt to the heads but would not line up correctly anyway to remedy this?
Thanks Guys, I appreciate the help.
JP
Originally Posted by SpeedCrazie
Are you talking about the piece for the throttle body pointing towards the passanger headlight? If so thats okay because my chage pipe goes that way anyways.
JP
JP
And with the TB if your gonna use the smaller 3.0 TB i wouldnt even bother with the intak manifold because why choke it with a TB but pay good money for it.
because some of that head area is cast thin and for that trouble with that nice manifold i would just use 3.5 heads which i have
I understand what you are saying and I am curious if I can retain the VQ30 Bottom End and adapt the VQ35 Head.....ahhh....what to do....
Originally Posted by vipervadim
Why can't somebody just design a good IM for us? It's not hard, just produce a FWD version of the 350z IM that fits under our hoods. They'd sell like crazy. Altimas, 5th and 6th gen maximas and 4.5 gens would be all over it. They'd make tons of dough.
Originally Posted by NmexMAX
Work in progress
Even if the Kinetix showed no gain on the 350z, it might show a gain on the 02+ Maxima/Alt etc.. But what do I know .. exactly nothing.
The 350Z intake manifold is an engineering marvel. I don't see how ANY aftermarket company could significantly improve on it. 105% volumetric efficiency at 5600 RPM will be EXTREMELY tough to beat.
They don't need to beat it, they need to match its power and make it suitable for FWD applications. The gains would be significant. SR20DEN's Secret Sauce Intake manifold already gives big gains over the original IM, and I doubt his modded IM is better than the stock 350z IM.
With all this said, i think SR20's manifold should go into regular production...
I wouldn't mind buying a 350z lower intake manifold.
And just to let everyone know you will need a powerbulge in your hood a couple inches and it will be offset on the hood
This is referring to the 4th gen or 5.5g? Or both? Or do you know if it's the same for the 5.5g?
I am too chicken to put it in regular production and it's more difficult for me to get them done now since I don't work at an auto shop anymore.
However, I have some ideas to make it even better to the point that everyone would want one over anything else. If I can find a way to pull it off I'll open the flood gates.
Whenever you're ready, we got the cash in hand, tons of us.
Well the one I have now is easy to copy (for those who have the right equipment) and that is what scares me. However the one I want to sell would be too complicated for anyone else to consider, and It would make the car go down the track even faster.
How much were you thinking of selling them (roughly)? If your price is fair AND the thing is complex no one will want to go through the trouble of copying them.
The aftermarket 350z IM's cost like 1g's. It would be funny if the Z/G guys ended up being jaleous of your FWD manifold
Most Z guys just have too much money and spend it on the latest product, little of them actual do tinkering/engineering on their own to improve a product. That's what makes the small Maxima community that does this unique..IMO.
I'd like to see what the Gen II SSIM is all about too.
I'd get one.
