Amps not cooperative
Old Jul 4, 2005 | 05:37 PM
pikers's Avatar
Any reason why two two month old Rockford amps won't turn on? Happened out of the blue. Snapped on faceplate, no sound.
Head is Alpine 9835, non-Bose, not the turn-on lead. I know this because I attempte to engage the amps thru the ignition lead from the car, which has worked before. Fuses intact.
Old Jul 4, 2005 | 05:43 PM
GrazsRootz's Avatar
if it happened out of the blue its prob broken as a rule
Old Jul 4, 2005 | 05:45 PM
GrazsRootz's Avatar
oh oops you said u got two, check the wiring and check the connection to battery and everything
Old Jul 4, 2005 | 06:58 PM
AscendantMax's Avatar
fuse on the amp ok? doublecheck all connections to the amp.
Old Jul 4, 2005 | 07:14 PM
DcMaN's Avatar
use a multimeter see if your getting voltage to your amp. Check your grounds and check for blown fuses
Old Jul 4, 2005 | 08:03 PM
mendon99's Avatar
tastey wheat
main fuse to battery blown? even if its still entact try a new one.
chisam14
Nov 6, 2018 08:56 PM
sliptap
Sep 30, 2015 05:57 AM
Redfox
Sep 28, 2015 10:41 AM
popdedop
Sep 11, 2015 11:17 AM
