Don't forget to Re-Align the Rear...
I was probably on of the first to install the new Cattman Rear Anti-Sway Bar...and let me say I love it. However, I would like to emphasize something I knew but forgot to do. Anytime you make a suspension change to an Independent Rear Suspension vehicle you should always have it re-aligned. The other day I was coming home from my vacation in Florida with one of my buddies behind me in his truck. He radioed me (we used portable C.B.s on the trip home) to let me know my rear left tire looked "kicked in" by about 15 degrees. I immediately knew why. I had my car re-aligned today and they told me the back end was bad (you could definitely tell by the tire wear).
Anyone who has done any suspension work should go have your alignment checked. Its not that expensive!
Sway bar has no affect on alignment
I had my rear sway bar, bushings and bolts replaced on my OLDS delata 88 Royale and never once did a rear alignment, not once, the rear tires never ever looked like they had wear and the car handled straight and took turns like magic.
Sway bar = better handling = no allignmnet problems (EVER!)
Unless Nissa F shizzz up, that should be the norm.
Kam
Kam
Originally Posted by Davidx34
So should we have the re-alignment or not when replacing suspension parts i.e sway bars
Stuts / Alignment
Just had my struts replaced third time. Nissan Service advisor indicated that they did my alignment as a complimentory service. I said shouldn't be done as complimentory but required when replacing stuts. He said no it wasn't required when struts are redone.
What a bunch of bull****!
Violator
Sep 9, 2015 10:14 AM
JoshG
Sep 5, 2015 10:10 PM
