A question about the rear shock piston rod nut.
Old Jul 13, 2005 | 06:46 PM
Whtmax'01's Avatar
When i was installing the rear shocks, the 14 mm piston rod nut is plastic coated on the thread. Due to this plastic i couldnt easily screw on the nut without the piston turning. I was afraid to grab the piston with anything so as not to void warranty. So instead i used a different 14 mm nut without the plastic coating which screwed on easily without the piston rod turning. So was the original nut important and should i take off the shocks and screw on the original nut?
Old Jul 13, 2005 | 07:48 PM
Whtmax'01's Avatar
anyone know?
Old Jul 13, 2005 | 08:12 PM
Kevlo911's Avatar
Kevlo for President
The plastic is there to make sure the bolt will not come undone on its own. "Thread Locker" There is a flat spot on the piston that you can use to grab and tighten.
Old Jul 13, 2005 | 08:28 PM
Whtmax'01's Avatar
so its likely the regular nut will come off in time?
Old Jul 13, 2005 | 08:31 PM
Kevlo911's Avatar
Kevlo for President
Maybe, It is hard to say. I do not wanna say it wont, but it might. There has to be a reason why it came with that type of nut
Old Jul 14, 2005 | 09:16 AM
zoner's Avatar
Another thing you can do - stick another nut on top of the one your put on (they call it a double or jam nut). It'll keep the original nut from backing out and it's alot simpler than pulling the whole strut back out.
Old Jul 14, 2005 | 06:51 PM
Whtmax'01's Avatar
I noticed just today that one of the shocks is screwed in farther than the other, at any case i put another nut on top of each piston rod. guess ill have to take that shock out sometime and tighten it farther.
Matt93SE
May 24, 2019 02:58 PM
Huttig2009
Sep 25, 2015 03:31 PM
homeyclaus
Sep 3, 2015 06:15 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
Greenmaxspeed
Aug 8, 2015 12:39 PM
