A question about the rear shock piston rod nut.
When i was installing the rear shocks, the 14 mm piston rod nut is plastic coated on the thread. Due to this plastic i couldnt easily screw on the nut without the piston turning. I was afraid to grab the piston with anything so as not to void warranty. So instead i used a different 14 mm nut without the plastic coating which screwed on easily without the piston rod turning. So was the original nut important and should i take off the shocks and screw on the original nut?
Another thing you can do - stick another nut on top of the one your put on (they call it a double or jam nut). It'll keep the original nut from backing out and it's alot simpler than pulling the whole strut back out.
I noticed just today that one of the shocks is screwed in farther than the other, at any case i put another nut on top of each piston rod. guess ill have to take that shock out sometime and tighten it farther.
Huttig2009
09-25-2015 03:31 PM
MAXSE5SPD
08-23-2015 12:06 PM
Greenmaxspeed
08-08-2015 12:39 PM
