Raw gas smell -- can it be caused by quality/octane of gas?
Here's a problem that really stinks:
For the first time ever, I'm getting the smell of raw gasoline upon start up, and it happened right after I decided to try mixing equal parts of Chevron 87 & 93 octane gas (to yield something equivalent to 91 octane).
Now, it may be because the 87 octane gas has a very, distinctive and strong smell that the 93 octane gas did not have, and I just did not notice it before.
Or, perhaps, Regular has a higher sulfur content since that is what it smells like?
Maybe the gas station's underground tank of Regular was on the low side and I got a lot of residue?
From what I know about smelling raw gasoline on start-up suggests there may be a problem with clogs or leaks in the EGR system, clogged or malfunctioning injectors, leaks in the manifold or Y-pipe, or just running way too rich.
For whatever the reason, the smell is there the day after I pumped the gas, and that is why I suspect that when I run this gas out, and fill it back up with straight 93 octane from another Chevron station, the smell will be gone.
Anyone else notice a change in odor (or an increase in odor) when changing grades or brands of gasoline?
Sometimes, the harder is your car to start, the more the fuel/air mix accumulates, and when the engine finally does fire up, not all of it ignites.
In other words, unburnt gas fumes get blown out the exhaust pipe, and if it blows back in your direction, it smells like raw gasoline.
I do recall now that my car harder to start after I had put in that bad batch of gas I bought. Now that I've changed the gas, it cranks in one or two turns of the starter with no bad gas smell.
You have a small leak in your fuel system somewhere. I don't see how the quality of fuel could cause a bad smell unless your can't can't properly burn it off. It would be the car in that case not the fuel.
I had the raw-gas-smell problem once. But it was due to a small plastic connector under the back of the car, near the spare tire well. It's where all the gas fumes collect--there's about 4 hoses on this connector. One was broken off. I'll try and get a pic if I can. It may be another place to look and it's pretty obvious once you know what you are looking at.
ef9
Oct 4, 2015 08:43 AM
